EJ8 Seat Belt Chime/Light
#53
Re: EJ8 Seat Belt Chime/Light
No, not for the tests you've been doing.
The seat belt light is independent of the integrated control unit. The seat belt warning chime depends on the integrated control unit. The reason that you need to check the bulb is to see whether there are two separate problems. You may find that a previous owner disabled both functions.
Would this be anything in the Integrated control unit as well?
Ill re-try everything tomorrow, but if nothing changes, what's the next step?
#58
Reconnect all connectors except the one under the seat. Do you measure voltage to body ground at the Red/Blu wire of that connector? If so, now use a small piece of wire or paperclip to short the two terminals of the connector. Then, when you turn the key to ON(II), does the cluster light come on and does the chime beep?
#59
The voltage on the connector is like 11.4 or something along those lines. When I jumped the two wires, everything worked.
So now what?
I didn't do the seat side, just the connector that comes from under neath the carpet.
When i jumped it, everything worked.
So now what?
#64
seatbelt switch worked fine this morning going to work, but when I left it didn't.
I think it's the switch on the seatbelt side because I clicked the little red seatbelt remover switch in while I was driving a few times (with the seatbelt off) and the light came back on.
Any way to test this or to fix the connection?
#66
There's a bad connection in one of the plugs. Start by unplugging the connector under the seat and C401, pack the connectors with dielectric grease, and then reconnect them. Do the light and chime now work?
#67
Well, I didn't do that, but the light came back on (before you responded). It mostly stays goes off when I don't have my seat belt on. It seems to be working well, but if it doesnt i just push the red seat belt button and it works.
sorry thats a mouthful
AndThenYouSay
04-07-2014 10:15 AM
erikiksaz1
10
12-22-2003 11:20 PM
