EJ1 Rear Sway Bar App.
Re: EJ1 Rear Sway Bar App. (H.crx-si)
you may have to swap out your LCA's for Si, Integra, or aftermarket LCA's. you will need LCA's that can use a rear swaybar. a few people use the stock 22mm ITR swaybar.
gsr or itr. but you'll have to get new lower control arms, because our civics dont come with holes to mount the endlinks. may i also recomend you buy a subframe reinforment brace, ej1 subframes are pretty thin and running a stiff sway bar with soft spring rates can rip out a nice peice of metal. check out http://www.a-spec-racing.com
Re: EJ1 Rear Sway Bar App. (b20zej1)
i Have a set of gsr rear lower control arms,a ITR(jdm)23mm rear sway, and a beaks subframe kit waiting for my ej1 when the damn canadian winter to let up.
Like mentioned above about subframe tearout, there are many threads on this subject if you search around a bit. Some of the crowd around HT may not trust in such a prodcut like beaks subframe kit and feel its lacking and run other bars\subfram reinforcement. the crowd including myself feel for my daily driven car its its more than enough. So just see what applys to you, but the beaks kit is the minimum i personally would run with a bar of say 20mm or more.Good luck
mingchi69
08-19-2005 08:34 AM
opeth13
06-02-2004 05:46 AM
aftermarket, bar, bars, daily, ej1, honda, install, intallation, lca, lcas, rear, stabilizer, stock, sway, swaybar
