Eibach vs. Progress Camber kits --> whats the difference?
Re: Eibach vs. Progress Camber kits --> whats the difference? (azn_outlaw)
I know you asked about eibach/progress....but how about Ingalls? I only mention that because I currently have a front/rear kit on my car. It's +- 3degrees in front and +-2degrees rear if i'm not mistaken. The local alignment shop tells me they find it very easy to adjust. So far, I have no complaints abot em. Hope this helps.
-rod
-rod
Re: Eibach vs. Progress Camber kits --> whats the difference? (RK)
I have the Progress kit... The front kit has 2 settings and the rear kit are two bolts with washers. As said in the instructions, you must get the pre-alignment specs first then istall the kit, then have the car aligned
how much did the ingalls cost? im also thinkin of gettin camber kits, had to higher my car because it started to waste alot on the inside and it still had big treads at the outside.
Re: Eibach vs. Progress Camber kits --> whats the difference? (00fbp)
I bought the ingalls (f/r) for $300 shipped. It was the cheapest i found. from http://www.ultraperformance.com. This is on a 98 civic....where the upper control arms are replaced (making it the most expensive)
VX
31
08-25-2003 04:42 PM
