are eg's n dc2's suspensions interchangeable
Alright heres the situation.. we might be trading coilovers and he has tanabe pro's on a dc2 and i have d2's on an eg.. will we be able to switch them without much modifications... like are they fully interchangeable..?? thanks in advanced.. i searched and couldnt find anuything about it except that the sway bars and all that will fit.. but w/e.. also i posted in here cause it didnt let me post in the suspension spot.. thanks guys in advanced!!
Re: are eg's n dc2's suspensions interchangeable (chuniepatuni)
plug and play
the spring rates might be a little higher on the dc2 but since they are aftermarket i doubt it
Imperious: Mod of Valor
Re: are eg's n dc2's suspensions interchangeable (fast95eg8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fast95eg8 »</TD></TR><TR><TD CLASS="quote">Yes, no mods required, straight switch.</TD></TR></TABLE>
All integra dc2 and eg civic suspensions are interchangable. However, the dc2 suspension will be stiffer on the EG because the dampers are matched to dc2's spring rate/and weight (depending on coilover setup/company). BUT if you're swapping from a Dc2 Integra Type R, you will need the rear lower control arms from the ITR which is around $50 from Honda. They're a good cheap mod to have. They give u a little extra wheelbase in the rear, and have this thing called passive toe steering which changes the toes in the alignment while cornering. also they have holes that match perfectly for a 23mm ITR rear swaybar with the beaks kit
boostedcivichatchbacksi
08-30-2004 09:26 AM
