egr lift sensor
ok. i have posted about this topic before trying to get someone to give me a pic of the egr lift sensor. i decided that it would be best to just take a pic of what i think the egr lift sensor is and have somebody out there identify it. heres the pic dudes. is this the egr lift sensor?
thanks http://www.we-todd-did-racing.com/we...MXk1NDE%3D.jpg |
Re: egr lift sensor (sIcWiTiT)
I would like to knwo too, I have a broken sensor on my h22 and believe it is the EGR. The pic you have is the broken sensor on my h22 if someone could confirm that is an EGR that would help big time https://honda-tech.com/forums/images/smilies/emthup.gif
that's an evap purge solenoid.
Re: (axtran)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by axtran »</TD></TR><TR><TD CLASS="quote">that's an evap purge solenoid.</TD></TR></TABLE>
x2 https://honda-tech.com/forums/images/smilies/emthup.gif |
https://i5.ebayimg.com/01/i/01/29/d4/70_1.JPG
the lift sensor is built into the EGR Valve (the blaock box on the top of the EGR with the three wires going to it), they come together when you buy a new EGR valve. |
Re: egr lift sensor (SonicGSR98)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SonicGSR98 »</TD></TR><TR><TD CLASS="quote"> https://i5.ebayimg.com/01/i/01/29/d4/70_1.JPG
the lift sensor is built into the EGR Valve (the blaock box on the top of the EGR with the three wires going to it), they come together when you buy a new EGR valve.</TD></TR></TABLE> https://honda-tech.com/forums/images/smilies/emthup.gif https://honda-tech.com/forums/images/smilies/emthup.gif |
Re: egr lift sensor (postman)
I need an EVAP purge solenoid then, thanks for clearing that up. Can these be swapped from motor to motor? or picked up pretty cheaply from honda? I have a couple of D series blocks lying around i'll see if they have what im looking for on them
Re: egr lift sensor (djnikko)
yes, the Evap Purge Solenoid can be swapped between engines easily. Just make sure they are the same looking and you will be set.
