EG6 Build Thread
EG6 Build Thread
As You Can See from the title Me and My Friend are Building a 1993 Civic Cx Hatchback.....The previous owner swapped the motor with a d16y7 but could not get it to start....the car was bought a lil over a week ago for $800........The Civic is not mine im just working on it......btw im 16 nd the owner is 17 lol
heres what we got so far
this was the lil work we did rite after we got it
sanded the fenders nd the hood a lil to prepare for body work
Today we did as much work as possible, mostly body work
we did the valve cover the intake, did some new wiring, removed dents nd shaved the washer nozel holes on the hood primered the bumper and fenders light gray and primered the hood black, then put it back on
as you can see the bumper is hanging off a lil but thats only because the bolt was missing, we will be getting another one tomorrow
engine bay looks okay now, gonna do a wire tuck in the near future
I Did get the engine to make some type of noise today but i cant really find what the issue is
here's the link to the video
http://www.youtube.com/watch?v=2Yy-x7K_hjc
if you have any idea what it could be please let me know
Re: EG6 Build Thread
Yeah it wasnt too bad but i got a feeling the problem with the motor is the ECU.....i checked it and its the ecu from the old d15 motor nd not the swapped d16 motor in it now.....it sounds exactly the same is the civic in this video
http://www.youtube.com/watch?v=EdISD...eature=related
D16Y7
Found in:
1996-2000 Honda Civic DX/VP/LX/CX
1999-2000 Honda Civic Special Edition - SE(Canada)
1996-1997 Honda del Sol S
1996-1997 Honda Civic Coupe LSI
Displacement : 1,593 cc (97.2 cu in)
Bore and Stroke : 75 × 90 mm (3.0 × 3.5 in)
Compression : 9.4:1
Power : 106 hp (79.0 kW, 107 ps) @ 6200 rpm
Torque : 103 ft·lbf (140 N.m) @ 4600 rpm
Redline : 6800 rpm
Rev-limiter: 7200 rpm
Valvetrain : SOHC (4 valves per cylinder)
Fuel Control : OBD2 MPFI
Head Code : P2A-2
Piston Code : P2E
ECU Code : P2E
Found in:
Compression : 9.4:1
Redline : 6800 rpm
Head Code : P2A-2
Piston Code : P2E
ECU Code : P2E
D15B8
Found in:
1992-1995 Honda Civic CX (U.S. model)
Displacement : 1,493 cc (91.1 cu in)
Bore and Stroke : 75 × 84.5 mm (3.0 × 3.33 in)
Compression : 9.1:1
Power : 70 hp (52.2 kW, 71.0 ps) @ 4500 rpm
Torque : 83 ft·lbf (11.5 kg/m, 113 Nm) @ 2800 rpm
Valvetrain : SOHC (2 valves per cylinder)
Fuel Control : OBD-1 MPFI.
Found in:
Compression : 9.1:1
yeah the ecu should not be the problem i my b16 i had in my ride was a obd2 and i just converted the dizzy to fit my wiring harness and used a obd1 p28 so yeah what i would do is check your firing order and then see if your getting spark and fuel
we used a tow strap but when we went to pick up the car someone had offered to attach it for us nd he ended up attaching it to the rad support, i could already tell it was wrong but its my friends car nd he was alrite with it so we left, 4 blocks later it came out so i re attatched the tow strap my self to th e actual frame of the car and we were fine after that
yeah they're pretty nice cars this one the body is in good shape (aside from the rad support) and had very lil rust.....i was gonna get a eg hatch for my self too but im gettin a 1992-1993 integra gsr instead in the near future, if not that then a gs then do a lsvtec swap
Got Some Better Pics and a lil More Body Work Done Today
we still need more work done to the body of course but we got alot accomplished in such a short time with such a small amount of money we will be done with the body soon
