Eg w/obd1 gsr. Throwing Knock sensor.. HELP!!
Old 10-23-2017, 04:57 PM
ef_hatchback's Avatar
Default Eg w/obd1 gsr. Throwing Knock sensor.. HELP!!
running a obd1 gsr swap with stock gsr ecu. I've added the wire including pins to tower plug from ecu. Purchased new knock sensor, checked continuity between ecu plug to knock sensor plug, checked out good. Cannot figure out why I'm throwing the code, motor sounds fine, hits vtec. The spark plugs have a black ring around two threads as seen in picture. Any ideas or something I am missing??? Changed rotor and cap.
Old 10-23-2017, 09:01 PM
Default Re: Eg w/obd1 gsr. Throwing Knock sensor.. HELP!!
No one?
Old 10-24-2017, 05:55 AM
keep trying to mess with it, but nothing yet. any ideas???
Old 10-24-2017, 07:53 AM
JRCivic1's Avatar
If you clear the code, how long does it take for the code to return ???
Old 10-24-2017, 08:22 AM
sometimes quick and other times it'll take a few minutes. only comes on while driving, has never come on idling or at rev
Old 10-24-2017, 01:29 PM
Fish Twig
tony_2018's Avatar
video of blinking cel light to verify code.
Old 10-24-2017, 03:08 PM
Here is a short video of the blinking cell
Old 10-24-2017, 06:09 PM
Technical Hero
HondaPartsHero's Avatar
Pics of how you wired it
Old 10-25-2017, 05:13 AM
will get pictures after work. The engine harness already had the plug, wire and pin, I wired it from the cabin harness putting a pin in the plug, running wire through firewall and down to the ecu putting the pin in D3. After i finished wiring, i ran a continuity test to make sure the wire had signal from one end to another
Old 10-25-2017, 05:57 AM
egsleepercivic's Avatar
did you use shielded wiring in the bay for the knock sensor?
I believe you only get the code if there is a wiring or sensor issue. If there is knock the ecu just pulls timing I believe.
Old 10-25-2017, 09:18 AM
Premium Member
94 Civic Si's Avatar
You may have continuity end-to-end, but I found that I did not have the connector pushed all the way in the plug at the ECU:
https://honda-tech.com/forums/honda-.../#post51298255
Old 10-25-2017, 09:20 AM
Fish Twig
tony_2018's Avatar
This, the knock sensor plug is shielded if I recall correctly when I pulled it off of a jdm harness to be re-used.
Old 10-25-2017, 09:45 AM
Premium Member
^^^ This...
See here, where @wxman94ej1 did a nice write up on his issues with the knock sensor: https://honda-tech.com/forums/honda-.../#post51324737
Old 10-25-2017, 04:22 PM
believe it is fixed. Drove it for a couple miles, hit vtec through 2nd and 3rd with no light turning on. I switched back to the old sensor, de-pinned the cabin harness and re-pinned it. Then made sure the pin was all the way in the ecu plug. So far so good. Little crap like that is such a headache, thanks guys
Old 10-26-2017, 12:45 PM
Premium Member
Glad that worked! Did you use shielded wire?
Old 11-10-2017, 08:12 PM
following up.....still good ?
antballs420
02-20-2006 06:35 PM
90jdmcrxdude
02-19-2006 05:45 PM
noob23
08-27-2004 03:59 PM
TRhatchCRAP
10
08-10-2003 11:52 AM
Quick Reply: Eg w/obd1 gsr. Throwing Knock sensor.. HELP!!
