EG w/ H22A:Fuel Line-any lines work?
Old 10-03-2010, 08:17 PM
kozanatos's Avatar
Default EG w/ H22A:Fuel Line-any lines work?
I am going to do a hswap wednesday on my eg.
JDM h22a
Is there a stock fuel line that i can just buy that is long enough to fit so i do not need to source a f22a1 fuel rail or get an aftermarket fuel rail?
It needs to be like a foot longer than an eg fuel filter to fuel rail line with the fittings...
Otherwise my friend knows of a place that MIGHT be able to make one for me.
Thanks.
Secondary question:
How do you remove the very bottom timing belt cog on the h22 ? it did NOT want to come off and we were worried about bending it.
Need to replace the seal there!
Old 10-03-2010, 08:24 PM
92civlude's Avatar
Default Re: EG w/ H22A:Fuel Line-any lines work?
The USDM H22 fuel rail inlet is on the right side. If you can get your hands on a USDM H22 fuel rail, the Civic hose will bolt right up.
I remember when I did my swap, I had to unbolt the fuel filter bracket and move it over a couple of inches. I dont remember why though!
Old 10-03-2010, 08:38 PM
kozanatos's Avatar
DOH obvious answer too, forgot usa has an h22. - Thank you might make my search easier.
Hmm but you dont think there is any other engine that has a long fuel line? even like an accord or something that is just longer because from the factory it has to go furthur
Old 10-03-2010, 08:44 PM
92civlude's Avatar
The 93-96 Prelude H22 fuel hose is about 1 inch longer than the Civic one. Youll need a custom hose if you decide to keep the JDM fuel rail.
boostjunkieee
06-20-2011 09:30 PM
egCivicH22
08-15-2007 09:35 AM
M2B4
02-21-2006 06:07 PM
SixguN
02-28-2005 07:45 PM
poison
09-08-2002 11:10 PM
Quick Reply: EG w/ H22A:Fuel Line-any lines work?
