eg stalls w/ ac on
Location: everything for everyone, and nothing for ourselves
eg stalls w/ ac on
i own a lightly modd'd '94 eg coupe si and when i'm idling @ a stop w/ the a/c on i stall nearly everytime. anybody have this problem?? help will be appreciated
Re: eg stalls w/ ac on (mikeyp5d)
I had this problem on my '92 civic. I increased the idle speed and changed the PCV valve. It seemed to fix the problem. Now my A/C doesn't work.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mikeyp5d »</TD></TR><TR><TD CLASS="quote">A/C + 1.6L = pain in the butt </TD></TR></TABLE>
It doesn not matter if you have a 1.6 or 2.4L. If your a/c is not serviced properly then its a pain in the butt.
Re: eg stalls w/ ac on (SirRevvs)
In response to what SirRevvs said:
"I tend to blame it on the 8.8lb clutchmasters flywheel."
you know what... i do have an ACT prolite flywheel. is there anybody else who think this could be true? or is it a small engine thing?
thanks for the responses by the way. i'll clean that iacv soon and see if it helps
When you turn on the A/C, the ELD (Electronic Load Detector) detects a load. (duh, lol) it should step up the idle a hair by using the IACV if I remember correctly. So take out the IACV and clean it with sensor safe carb cleaner. Check the obvious items also, like plugs, wires, cap/rotor, air filter. Do you have a CAI installed? CAI's decrease the air velocity and can mess a tad with idle.
Re: (FizzGiGG55123)
Right but when you have a lightweight flywheel the engine slows down too fast when you disengage the clutch so it tends to stall (my theory). Only happens when the A/C is on (engine under load)
Re: (SirRevvs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SirRevvs »</TD></TR><TR><TD CLASS="quote">Right but when you have a lightweight flywheel the engine slows down too fast when you disengage the clutch so it tends to stall (my theory). Only happens when the A/C is on (engine under load)</TD></TR></TABLE>
that's actually plausible. I have an 8 lb flywheel and I have the same problem.. only happens when I rev REALLY quickly, then let off completely
