EG SiR cluster tachometer accurate?
I have a 93 CX and I swapped an EX/Si cluster in it and the tach was way off, like over 25%. I heard this was a common problem...so i took that cluster out and put the stock one back in and got a 2.5" autometer tach. Now I dont like the look of it because im going for a sleeper look. My question is: is the SiR cluster tach known to be accurate or do people have the same problem as with the EX/Si clusters?
Re: (pythoner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pythoner »</TD></TR><TR><TD CLASS="quote">how do you know that it was 25% off... that is a lot or RPM to be off!</TD></TR></TABLE>
hondata and wideband datalog say so!
it was over 1000rpm off at high rpm.
1 Post
Re: EG SiR cluster tachometer accurate? (BlueIntegraBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy »</TD></TR><TR><TD CLASS="quote">Stock tachs are inaccurate up to like 500 rpms. You will have the same problem depending on which one you get. One tach may be more accurate than another.</TD></TR></TABLE>
Correct!
Correct!
Re: EG SiR cluster tachometer accurate? (ham)
I dont even look at my stock tach anymore, Full Throttle Launch set to 3,500 (crap *** tires) cel shift light at 6,800 (SOHC ZC Vtec no high rpm power) and let the computer tell me where i am at.
Unless i get really noisey then i pull out my laptop and hook up crome pro
Punker1234
26
06-22-2015 06:33 PM
TheoneTheycallVille
19
08-12-2008 01:58 PM
