EG Shell Project...
Old 01-20-2009, 03:05 PM
  #26
WhiteBB2's Avatar
Default Re: EG Shell Project...
BTW, Thanks for everyones good luck wishes. I hope it comes along nice and quick.
Im going to need help/advise when installing a motor.
Anyone down?
-AG
Old 01-21-2009, 07:32 AM
  #27
WhiteBB2's Avatar
Hopefully picking up my SI rims this weekend!
-AG
Old 01-21-2009, 08:01 AM
  #28
xsaxisx's Avatar
sleeek looking civic, lucky no QP rust.
Old 01-21-2009, 07:15 PM
  #29
WhiteBB2's Avatar
So, Dude sold the SI rims I was going to pick up...
SUX!!!
Oh well, Search continues.
Old 01-21-2009, 07:17 PM
  #30
WhiteBB2's Avatar
Old 01-21-2009, 07:34 PM
  #31
KUMAR's Avatar
so what color is the finished car gunna be?
this seems like a very extensive project....good luck to you!
Old 01-21-2009, 07:39 PM
  #32
WhiteBB2's Avatar
Car is going to stay white with the black roof. Not really an extensive project, just have to get the parts that I am in need of so I can throw them on there.
Old 01-22-2009, 04:44 AM
  #33
WhiteBB2's Avatar
Ok, I have found my swap and donar car. The car is a 97 EX Civic with a swapped JDM B16a motor/trans.
I am going to atempt this swap alone and have never done it before. Does anyone have any suggestions?
I am going from an OBD1 car to an OBD2 engine, What kind of problems will I run into? This is a VERY commmon swap so I know a lot of you have these answers. (If we were talking H22 info then I would have a lot of the knowledge, but im in the Civic world and am kinda lost.)
Old 01-22-2009, 04:53 AM
  #34
sp00ledbseries's Avatar
a jumper harness will solve your obd conversion. you will need a eg b series shift linkage,92-95 mounts,b series axles. take your time.
Old 01-22-2009, 04:56 AM
  #35
Two Piece
Go_Race_Your_Self's Avatar
nice
Old 01-22-2009, 05:10 AM
  #36
keving85's Avatar
oh yeah.... last thing i ran into helping a friend....... the fuel line runing from the fuel filter to the fuel rail is not long enough to go around the intake tube.... must use a B series line...... (talking about the one with the banjo fitting)..... and SI wheel's i love it keeps the car clean and sleek.... along with keeping factory body lines..... that i am a fan of.....
kev
Old 01-22-2009, 06:11 AM
  #37
WhiteBB2's Avatar
Thanks for the information guys!
Kev- Are you lookin for any 97 civic parts?
Also, IF anyone is looking for any Integra front seats I have a set that I will let go cheap. Along with all the other interior parts from my donor car. There is an SI cluster, etc...
Old 01-22-2009, 06:19 AM
  #38
i might be interested with the shell pm me a price if you want to sell it
Old 01-22-2009, 06:27 AM
  #39
WhiteBB2's Avatar
PMed
Old 01-22-2009, 06:29 AM
  #40
iamthefollower's Avatar
you can honestly use any b series shift linkages EXCEPT del sol linkages.. I have a set of 93 Gsr's in mine... you don't have to use an obd2 computer for the obd2 motor... since you're putting the motor in an eg, buy an obd1 gsr or obd1 b16 distributor thats all you really have to change on the motor when putting it in the car, you will need to take and put an intake temperature sensor somewhere.. in ur intake tube would be good.. that's where they are on the obd2 cars.. get a chipped p28 for the computer, or run a chipped p72, stock p72, stock p30... I put a JDM Obd2 b16 in my hatch a few months ago.. I just changed my distributor as I stated in this.. I didn't even change my fuel line from the fuel filter, and my intake tube goes over it.. but it is stretched so it would be good to change, plus you need the throttle cable conversion bracket or b series throttle cable... if you need to know anything else, i'll check back...
Old 01-22-2009, 12:25 PM
  #41
WhiteBB2's Avatar
Yeah, I am going to have the complete car so this swap shouldnt be bad to do...I will have every piece off of this donor car. Cables, ECU, Fuels lines, ETC....
Old 01-22-2009, 03:08 PM
  #42
Oh yeah, you need to get a back L mount for the transmission from a 94 up integra... the Ek's have to use an Si back L mount which is going to be too short for you to use on your Eg.. The ECU from that donor car is going to be obd2, I would just buy an OBD1 ECU instead of a jumper harness... I mean the harness is going to be cheaper, but you can do more with the obd1 computer...
Old 01-22-2009, 05:18 PM
  #43
WhiteBB2's Avatar
iamthefollower...you seem to know what you are doing...would you like to come up here and assist me with this project? You are def throwing things out to me that I have not thought about and it is helping a lot but I am going to start getting confused...
hahaha....
Old 01-22-2009, 05:19 PM
  #44
WhiteBB2's Avatar
here i thought that the bseries was basically a direct swap in the 92-95
Old 01-22-2009, 07:42 PM
  #45
keving85's Avatar
no not any 97 parts...... but i will keep i look out for some SI wheels for ya.....
i just finished pulling my motor out of my car tonight.... sitting up on a stand now..... to lazy to tear the block apart.... do
Old 01-22-2009, 08:51 PM
  #46
hahaha....
Honestly man, if we lived closer together, I would definately help you out lol.. I have done at least one of every honda swap lol, except for the K20 and a J series.. I know a bit on each swap, just waiting to actually get the chance to put them in a car...
I also wanted to tell you that on your mounts.. I have the Ex aluminum driver side mount a 1.5 Cx tranny mount and a 97 Automatic back L mount.. the automatic back L mount will bolt up on 3 out of the 4 holes.. I had to do this because I couldn't find a mount anywhere for my car so I just got what I could, but if you can I would def. get some stiffer mounts, Hasport or whatever you may like.. because the mounts that are coming in your donor car won't bolt up, if i'm not mistaking..
Old 01-23-2009, 01:12 PM
  #47
WhiteBB2's Avatar
I read that all the mounts will bolt up...I could be wrong.
-Researching now.............................
Old 01-23-2009, 05:18 PM
  #48
I know the back L mount def. won't bolt up, it's going to be about 2 inches shorter.. it's the other 2 i'm not sure on.. but i'm leaning more towards they're not going to bolt up... i'm going to search with you.. I'm just going to double check myself lol.. don't wanna send you wrong info...
Old 01-24-2009, 10:43 AM
  #49
WhiteBB2's Avatar
Update:
My donor car that I was going to pick up this friday, was sold yesterday out from underneathe me! The shitty part about the whole deal is that my own COUSIN was the one that did it!
-Back to the drawing board!
Old 01-24-2009, 08:01 PM
  #50
ah man.. that sucks dude.. Hey, you should put you an H22 over in there.. I know here the H swaps are cheaper than the B series swaps..
Quick Reply: EG Shell Project...
