eg rear sway?
Re: eg rear sway? (madeinjapan)
is 23mm overdoing it?i dont have a real agressive suspension. i would equip a beaks kit prior to use...
Shawn
Re: eg rear sway? (StanBo)
Do you guys have a link for the beaks kit? That is a kit to protect the undercarraige correct?
It prevents the rear swaybar mounting brackets from ripping the rear subframe. If you're getting a GroundControl swaybar, it comes with sufficient mounting bracket support, so make sure you need it before you buy it. But it is good kit!
I just got an ITR swaybar installed on my EG today and I'm instructing at a skid control class this weekend, so I'll have a good chance to test out the oversteer this weekend... I'll let you know what I think.
edit: grammar
[Modified by SpiceyRice, 8:22 PM 3/22/2002]
Re: eg rear sway? (brokstar)
Your gonna lose the *** end and burn in a firey crash!!!!! Do it!
[Modified by madeinjapan, 7:31 PM 3/22/2002]
Another question.
I know (think so) that the beaks kit is for aftermarket sway bars.
Would it also be beneficial to stock sway bar installations?
Overkill?
Or would it just not work due to clearance issues? Could I use longer bolts if I install the beaks first and then attach the stock sway bar mounts?
Overkill?
gamby
11-10-2007 08:31 PM
Your opinions on the ST 19 mm rear sway for an eg/eh or whatever. only if you have experience with t
Rratedcivichatch
01-16-2003 04:16 PM
