Eg Rear Lower Control Arm Question
i been wanted to put my LCA's in but when i went to put on when i installed my coilovers the bolt the bolts to the rear knuckle is siezed on... u think some WD40 and heat will do the trick to break it loose without breaking the bolt...
or...
if the bolt does break it it a ez fix to replace...
or...
Re: Eg Rear Lower Control Arm Question
Pb blaster is the secret juice. And if it breaks drilling and headaches. It's been posted before search for other ideas.
I had that happen to me. I used a grinder with a cut off wheel to cut threw the bushing on both sides. Then had to replace the bushing. It sucks.
Tong.Y
06-14-2010 12:33 AM
ActiveAero
05-14-2006 10:22 AM
dutchman5
11-27-2005 06:41 PM
