eg rear camber issues
After much reading on a number of forums , and chewing through my tyres , ive decided to look into camber kits/toe kits , from what ive read it appears toe affects camber more , is it really worth getting a toe kit and then getting an alignment ?Also then adding a rear camber kit , the car is an everyday driver who here uses such kits if so did it make all that much difference being adjustable alignment would be easier? Is it worth the money? My car is currently dropped 2.5 inches in the rear and 2.25 at the front ....
Re: eg rear camber issues
you dont need a camber kit, and im a little confused by this, toe affects camber more??
you really need to read through it.
take take your car in a get an alignment.... camber is not adjustable on civics... have them get the toe to 0 and then you should be fine. toe affects your tires A LOT
camber DOES affect them, but not nearly as fast as toe does. if you buy either kit your wasteing your money.
i just came back from getting my alignment done , it was well and truly off... thanks the information i was provided is what i was mentioning im not sure whether its factual hence why im asking here .... yea i thought buying them would be of not much usage .... thanks man
