EG radiator wiring
EG radiator wiring
Trying to finish up my first swap (JDM B16 into an EG-92 CX) and I have a few last wiring issues
Did some searching and found that the Rad fan should be running to A12 and that the wires should be yellow w/green stripe and green w/orange stripe
but
When I'm looking to plug the radiator fan in I see two different sets of wires:
1: Black w/red stripe and black w/brown dashes
and
2: Blue w/red stripe and yellow w/green stipe
I do not want to plug something in wrong and blow something up
Thanks for the help
but
and
Thanks for the help
A12 runs a relay not the fan directly.
those wire colors do not match up to what the 92's wiring should be, which harness are you using?
logically there are two wires at the fan, one is constant ground. find that one with a meter and the other should be obvious.
