eg ls swap.
eg ls swap.
im getting a whole swap from a 94-95 ls and i have a 92 civic hb will everything from the integra bolt up to my car or will i need to get somthing different?
Re: eg ls swap. (shizkabob3421)
yes everything will work, I see you have a 92 that has the map sensor on the firewall and the plug for it will be there too. the Integra motor will have it on the throttle body, and the plug will be on the engine harness. So unplug the one on the firewall and use that plug for the one on the throttle body and just let the plug on the Integra harness hang. otherwise just make sure you get the Integra shift linkage, axles, ecu, throttle cable, driverside engine mount, and rear T bracket
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shizkabob3421 »</TD></TR><TR><TD CLASS="quote">but thats all i have to do?</TD></TR></TABLE>
pretty much, here this link should help you:
http://www.c-speedracing.com/h...p.php
the only difference is that you will not be wiring up the motor for vtec since the ls is vtecless.
Re: eg ls swap. (MeGotRoundEye)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MeGotRoundEye »</TD></TR><TR><TD CLASS="quote">wont he have to repin the harness for the ecu? i was thinkin about doin the same thing to my car but mines a 93 cx. are they different?</TD></TR></TABLE>
nice link.. very helpful
not really, if he doesn't have vtec and it's not a auto to manual swap, he can use his existing ecu.
* B A N N E D *
Re: eg ls swap. (USDMCIVICHATCH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USDMCIVICHATCH »</TD></TR><TR><TD CLASS="quote">yes everything will work, I see you have a 92 that has the map sensor on the firewall and the plug for it will be there too. the Integra motor will have it on the throttle body, and the plug will be on the engine harness. So unplug the one on the firewall and use that plug for the one on the throttle body and just let the plug on the Integra harness hang. otherwise just make sure you get the Integra shift linkage, axles, ecu, throttle cable, driverside engine mount, and rear T bracket</TD></TR></TABLE>
good listing.
good listing.
Re: (Madrek)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Madrek »</TD></TR><TR><TD CLASS="quote">I would have gave you my ls motor that sits in my garage since hmmm forever...Takes up rooms thats about all the good its doing for me...Good luck on the swap tho</TD></TR></TABLE>
Wanna give me your ls? lol
nolanator6
04-12-2011 07:45 PM
STPREZ
02-19-2005 08:41 AM
TopStreetDSM
18
01-02-2005 02:55 PM
