EG or LS Intake
EG or LS Intake
I have a 93 EG8 with an LS Swap. I was looking to put a stock intake back in. Curious if I could use an EG intake/airbox or would I have to use the LS setup? I know it might be a noob question but i wasn't sure and I already searched and couldn't find an answer. Thanks all and happy driving
Re: EG or LS Intake
I think you have to use the LS intake but I may be mistaken. It just has to fit over the trottle body so other than that, if you can get the original EG intake to fit then you're good haha. But I'm 100% sure you either have an OEM LS intake manifold with the OEM trottle body or an aftermarket one specific for the B18.
Re: EG or LS Intake
I believe you must use the B-Series intake manifold, but you should be able to use the EG airbox. I'm pretty sure that the intake pipe is the same size, so it'll bolt up to the throttle body. However, i'm not entirely sure. Try it out yourself and post up your results.
Re: EG or LS Intake
get the sir2 airbox they bolt up like stock and have a bigger tube than the stock civic one, thats what I use with a kn drop in filter for the civic it fits the sir2 box
Seagull Management
Re: EG or LS Intake
The airbox is the same as any other one, its just the intake tube thats different (ends of the tube are all the same size, but the D-series versions have bell shaped end, SiR/Del Sol VTEC are the same size from end to end.
Re: EG or LS Intake
Im not 100% sure as well, but i think you can use the stock eg intake on your ls motor, if everything fits then you should have no problems, in my opinion they have the same purpose and they look similar.. but to be on the safer side, might as well get the stock ls one.. PICK N PULL!! lol
Re: EG or LS Intake
I was lucky enough to find a delsol vtec stock intake at the parts yard its a little bit bigger and it like a charm on my wifes b18 EG8 and as EG8 said the air box themselfs are exactly the same
transpar_nt
12-29-2005 12:50 AM
