EG hatch - Where do I connect these A/C wires?
Old 04-27-2016, 10:53 PM
@uton's Avatar
Default EG hatch - Where do I connect these A/C wires?
hi guys,
my eg hatch has a new engine d15b and my a/c system is using the old lines, have obd1harness with p28c52 ecu, only to find out that A15 ang B5 was cut and wasn't connected to any wires. my question is where should i connect these two wires to make my a/c working again. by the way my a/c is running before but was using this toyota idle up to bring the idle when it goes down. but these stuffs plus the wires are pain in the *** to see it everyday. is this still possible?
pls help
Old 05-01-2016, 06:22 PM
@uton's Avatar
Default Re: EG hatch - Where do I connect these A/C wires?
Pls help guys, any inputs is much appreciated
Old 05-01-2016, 10:45 PM
vtechsjc's Avatar
ECU A15 is a black/red wire that is connected to pin 4 on the a/c clutch relay.
B5 is a blue/red wire that connects to pin 1 at the a/c pressure switch.
Old 05-02-2016, 07:49 AM
Former User's Avatar
Correct!
Old 05-02-2016, 08:10 AM
fcm
Old Fart
fcm's Avatar
Hmmmm. I wonder how the A/C was working if ECUs A/C clutch relay control lead was not connected????
Need more info on how this A/C system was wired before. 94
Old 05-05-2016, 06:31 AM
@uton's Avatar
my a/c was working before but i was using this idle up by toyota to compensate the idle when it goes down. i will take a pic of my relays as i see in there a side by side relays and not sure though w/c is the ac clutch relay though i can see a blk/red on the other and blue/red on the other one. as per above diagram i guess i have an idea. thanks for the replies i'll post the pics once got them.
Old 05-05-2016, 06:49 AM
@uton's Avatar
does it mean that pin 4 color is blck/red and pin 1 is blue/red respectively? sorry newbie.
Old 05-05-2016, 09:12 AM
Old 05-06-2016, 12:02 AM
@uton's Avatar
Originally Posted by RonJ
thanks man, will keep you posted once I wired ang tested it.
Old 05-31-2016, 09:49 PM
@uton's Avatar
i think my a/c now is working perfectly. i'll monitor it for a week and keep you posted for updates.
thank you so much for all the helps!!! really appreciate it.
crxaddikt
06-23-2017 05:08 PM
LilKrnThugBoi253
07-13-2008 07:30 PM
EFz6er
10-31-2005 09:19 PM
B18EG6
Audio / Security / Video
06-26-2003 08:37 AM
AlphaQup
03-19-2003 09:25 PM
Quick Reply: EG hatch - Where do I connect these A/C wires?
