eg foglight help...again
ok since i got few responses to my last post im gonna try it again. i bought a depo fog light kit for my eg off ebay, but the instructions were unreadable, and im just confused about where stuff needs to be wired. here are some pics of what i don't know goes where:
http://www.clarkson.edu/~gleinerm/fo...light_fuse.JPG http://www.clarkson.edu/~gleinerm/fo...ght_power1.JPG im assuming this connects to the wire in the next picture (hanging off my fender) http://www.clarkson.edu/~gleinerm/fo..._hoodright.JPG http://www.clarkson.edu/~gleinerm/fo...t_hoodleft.jpg http://www.clarkson.edu/~gleinerm/fo...ayfusering.JPG ok where the do i connect this thing that looks like the power wire? we hooked it up to the battery, turned everything on, but the relay just gave a loud buzzing noise and the lights didnt come on. we checked the grounds and they were good...am i just being stupid or what? any help is appreciated! thanks [Modified by gleinz, 5:03 PM 3/27/2003] |
Re: eg foglight help...again (gleinz)
cmon, no one can help?
IM user "White95CivicSi" as he is the resident honda-tech expert on 5G Civic foglights (OEM and OEM-style). If I remember, he currently has Depos also, and can now install Depos from scratch in an hour or less...
Re: eg foglight help...again (Outrun)
aight thanks man, ill check that out.
im me at aim m1kevtec
i installed two sets of these |
Re: eg foglight help...again (M1kevtec)
you're right about the red wire in your hand going to the one by the fender. where the fuse is the red wire with the circle connects directly to the battery. if you need me to i'll take pics tomorrow and post it up. it's late, i'm tired, and i can't remember about port 2, maybe u need to move it 2 spaces to the left.
[Modified by White95CivicSi, 8:17 AM 3/28/2003] |
Re: eg foglight help...again (White95CivicSi)
connect that red wire in ur car to the red wire on the fender...
as for the red wire from ur foglights harness, yes it connets to the power Because of the disabled archive function, i am unable to confirm you that the port is number 2... i forgot... if port number 2 is right, it should turn on.. OH, you need to turn on your headlights before you can turn the foglights on... good luck |
Re: eg foglight help...again (TurBoXBirD16)
connect that red wire in ur car to the red wire on the fender... as for the red wire from ur foglights harness, yes it connets to the power Because of the disabled archive function, i am unable to confirm you that the port is number 2... i forgot... if port number 2 is right, it should turn on.. OH, you need to turn on your headlights before you can turn the foglights on... good luck |
Re: eg foglight help...again (dnt94civic)
got it....i'll post some pics soon.
