EG civic Front A Arm bolt and Nut
Hello,
I used the search feature and did extensive googling, I found countless threads on the front LCA bolts for where the bushings and shock go but none for the part number or size on the bolt that goes through the LCA and to the A arm?
Would anyone happen to know the Honda part number or the size or where I can find one?
I've tried looking up the oem parts, but it shows the entire LCA put together and no index for the hardware that holds the a arm to the LCA.
Thanks!
Thanks!
Re: EG civic Front A Arm bolt and Nut
Do you mean the two bolts that secure the radius arm that usually comes attached to and included with the LCA? Radius arm highlighted in red here
You could remove the other bolt and take it to the local hardware store and just grab a bolt and nut that matches the length, diameter and thread pitch. It's probably just something like 12x1.5 or 12x1.25, similar to wheel studs/lugs. Just make sure you get something really sturdy like Grade 8 or Grade 10 fasteners. Should be $3 bucks or less and out the door.
I gotta ask, though... How and why do you need that bolt/nut? That radius arm usually has no reason to ever come off the LCA.
OP is talking about the two fasteners pictured here circled. They secure the radius arm to the lower control arm. It is sold by Honda as a unit/assembly, and those bolts/nuts are not sold separately. The image attached is from HondaPartsNow
Yea, that's what i suggested. Just remove the other bolt from the other LCA, take it down to ACE or Menards or whatever your favorite place is and match it up. Most of those places have isles of various fasteners organized by grade, thread pitch, diameter, length, head type, etc. It's probably just a flanged Grade 10 12x1.25 bolt or something like that. Similar to lug stud size.
talks to himself
Junkyard or craigslist. OP is from NW Indiana. The Chicago craigslist almost always has listings for front LCAs for around $40.
