eg brake problem HELP
Old 09-22-2008, 03:28 PM
Civic-Kids's Avatar
Default eg brake problem HELP
my sister hatchback (auto) having an problem... when u make an full stop (red light). the car came to an full stop. it seem to be ok until u kept holding on the brake pedal (the car started moving slowly). u need to press more on the brake to stop the car. after a few second pass it repeat again until the brake pedal cant go any deeper. i told her to just use e-brake. any1 know? (SRY FOR MY BAD ENGLISH)
we just replace new brake, still doing the same
brake fluid still full
Old 09-22-2008, 03:30 PM
vtecb18c's Avatar
Default Re: eg brake problem HELP (Civic-Kids)
bleed the breaks again it sound like theres air in the lines still
Old 09-22-2008, 03:46 PM
jimmy o.'s Avatar
sounds like the seals in the master cylinder are shot. You may could bleed the system but its fairly common on older hondas for them to need a new master cylinder at some point or another.
Old 09-22-2008, 03:52 PM
vtecb18c's Avatar
Default Re: (jimmy o.)
what year is the car? i know the thread is 92-00 but if its newer, the master cylinder/MS gasket should not have gone bad on you....its its in the mid 90s than yea its a possibility
Old 09-22-2008, 06:35 PM
Civic-Kids's Avatar
Default Re: (vtecb18c)
it an 94
1 more than i forgot to add.. it mostly do it when it hot (day time)... at night it seem to be ok...
Modified by Civic-Kids at 7:42 PM 9/22/2008
Old 09-22-2008, 06:46 PM
gsrhatch2356's Avatar
master clyinder
Old 09-22-2008, 06:51 PM
ef1.8's Avatar
Default Re: (Civic-Kids)
I knew that after bleeding the brakes several times (as good as it was gonna get) and still had same problem you describe, I changed the mc and problem gone.
Before buying any parts make sure their well bled first
Old 09-22-2008, 06:53 PM
Civic-Kids's Avatar
Default Re: eg brake problem HELP (gsrhatch2356)
thx every1... i'll try change the master cylinder n c wat happen..
kelviiv
01-09-2011 11:31 AM
s10cky
17
12-20-2006 07:19 PM
tonezilla
12-23-2005 02:24 AM
PatrickGSR94
04-29-2004 10:02 PM
The_In_Kid
07-07-2002 11:45 PM
Quick Reply: eg brake problem HELP
