eg b series swap mounts ??
ok ive searched and read that you can use the stock mounts. now what i dont understand is, do you use the b series brackets, like the drivers t belt side and the rear bracket and just use the d series rubber mount ? i know i need to change the 2 lower front mounts to b series. what about the passenger side bracket, do i use hte d series and hte d series rubber mount?
its kind like what bracket and what rubber mount to use for all 3 mounts |
Re: eg b series swap mounts ?? (civickiller)
depends on what b series. on a b16 u can use ALL STOCK MOUNTS except the rear bracket which needs to be from a del sol vtec or 99-00 si.
for b18 u need the drivers mount from a 94+ teg and the rear bracket. |
Re: eg b series swap mounts ?? (CRXified)
its an ls motor.
so for the ls motor ill need the ls drivers side 94 and up integra bracket and rubber mount? and for the rear i only need the 94 and up integra rear bracket and i can just use the stock d series rubber mount? what about the tranny side? do i just take off the d series one and bolt it up to the ls tranny? thanks |
here ya go, ( found it on a quick search)
http://www.ff-squad.com/tech/mounts/...HCMounts_1.jpg props to ff-squad.com https://honda-tech.com/forums/images/smilies/emthup.gif |
