ef, eg, eh, ej, ek... EXPLAINED
#27
Re: ef, eg, eh, ej, ek... EXPLAINED (ninety3EX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">6th Generation (1996-2000)
EG1 D15B8 USDM 1996-1997 del Sol (8-valve)
EG1 D15B7 USDM 1996-1997 del Sol S (SOHC)
EG1 D15Z1 USDM 1996-1997 del Sol VTEC-E (SOHC)
EG2 B16A2 USDM 1996-1997 del Sol VTEC (DOHC)
EH6 D16Z6 USDM 1993-1995 del Sol Si (SOHC</TD></TR></TABLE>
ok this information is wrong.
my wife has a 97 del sol, and in 96 they changed motors, and therefore have the same motors as the civic. i tried to go and take a picture of it, but it's dark, and it didn't come out, but i know for a fact that the del sols in 96-97 had the d16y7, and d16y8...
if someone has doubts i can try and retake the picture of it in the morning, but i'm 100% positive on this
#29
Re: ef, eg, eh, ej, ek... EXPLAINED (V-GRIP! EG)
You've got some good info there, but too bad no one will ever be able to search for this thread again unless they type in "EXPLAINED". I'd suggest changing the title if you can do that..
Mike
Mike
#30
Re: ef, eg, eh, ej, ek... EXPLAINED (sledgehammer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sledgehammer »</TD></TR><TR><TD CLASS="quote">You've got some good info there, but too bad no one will ever be able to search for this thread again unless they type in "EXPLAINED". I'd suggest changing the title if you can do that..
Mike</TD></TR></TABLE>
Or you can just search for "chassis codes" and get the thread from which the thread starter copied and pasted the info from.
#32
Re: ef, eg, eh, ej, ek... EXPLAINED -- Chasis Codes (ninety3EX)
First of all you can't/didn't change the title of this thread... don't believe me, look at the name of this thread in the Civic Forum now to see what i mean.
And secondly, it's spelled "Chassis" not "Chasis."
#34
Re: ef, eg, eh, ej, ek... EXPLAINED -- Chasis Codes (VX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VX »</TD></TR><TR><TD CLASS="quote">First of all you can't/didn't change the title of this thread... don't believe me, look at the name of this thread in the Civic Forum now to see what i mean.</TD></TR></TABLE>
Oh well, i tried
Oh well, i tried
#36
Re: ef, eg, eh, ej, ek... EXPLAINED -- Chasis Codes (Grimm)
Here's an easier way...look at digits 4-6 on your VIN. That, my friends, is your chassis code.
#37
be professional
Re: ef, eg, eh, ej, ek... EXPLAINED (cozmo2312)
7th-gen codes are incomplete. G7 CTR is EP3, and there is no K20C1 engine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cozmo2312 »</TD></TR><TR><TD CLASS="quote">
if someone has doubts i can try and retake the picture of it in the morning, but i'm 100% positive on this</TD></TR></TABLE>
Correct, no D15 in North America after 1995.
'93-95 USDM del Sol S used the D15B7, '96-97 used the D16Y7
'93-95 USDM del Sol Si used the D16Z6, '96-97 used the D16Y8
'94-95 USDM del Sol VTEC used the B16A3, '96-97 used the B16A2
#38
6th generation column, 96-97 del sol si's come with a d16y8 and have the same chassis (incl 4 wheel discs, suspension, power options, etc) as the 96-97 VTEC model.
I'm 100% positive on this. http://www.teamdelsol.com also has data on this.
#41
Re: ef, eg, eh, ej, ek... EXPLAINED -- Chassis Codes (ninety5vx)
A bit confused..
I got this:
D17A1- 1.7L SOHC non-VTEC '01+ Civic DX/LX (115hp)
D17A2- 1.7L SOHC VTEC-E 01 Civic EX (127hp)
from http://www.superhonda.com/foru...69891
which would suggest my '03 EX coupe with the VTEC 127hp 1.7L engine is a D17A2... but according to your list, mine is actually an A1. Also, isn't VTEC-E the engine for HX?
I got this:
#42
Re: (VX)
And the Del Sol, even though was still made after 1995, the chassis remained the same. It wasn't totally redesigned.
not but it was changed over to OBDII and started using the newer d's like the d16y7 (someone else posted this) and the d16y8
*edit* and they changed the front bumper, got rid of those ugly aux lights...
Yeah I got a D16y7
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R »</TD></TR><TR><TD CLASS="quote">Correct, no D15 in North America after 1995.
'94-95 USDM del Sol VTEC used the B16A3, '96-97 used the B16A2</TD></TR></TABLE>
YEAH
Yeah I got a D16y7
YEAH
#43
Where did I go wrong? Somewhere on here I was told all 92-95's were EG's. Thus my login. Now I discover my 94 Coupe is not an EG. What gives?
#44
Re: ef, eg, eh, ej, ek... EXPLAINED -- Chassis Codes (EGCoupe56)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGCoupe56 »</TD></TR><TR><TD CLASS="quote">Where did I go wrong? Somewhere on here I was told all 92-95's were EG's. Thus my login. Now I discover my 94 Coupe is not an EG. What gives? </TD></TR></TABLE>
What gives? You were told wrong info. Now suck it up and go change your user name!
j/k
j/k
#45
like someone else said. Look at your VIN# . . . 4-6 is what you have . . .
So, nobody in the US actually has an EK (except the few CTR's that are here)?? Strange!
Steve
Steve
#46
Re: ef, eg, eh, ej, ek... EXPLAINED (peagreenhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by peagreenhatch »</TD></TR><TR><TD CLASS="quote">i will still and always call my car ek.. </TD></TR></TABLE>
Lucky my car is an ek
#47
Re: ef, eg, eh, ej, ek... EXPLAINED (MrMacros)
u forgot the EDM ek1 with a d16z and automatic transmission
and the EDM ek3 got the d15z6 engine in it
but nice list
but nice list
#48
Re: ef, eg, eh, ej, ek... EXPLAINED -- Chassis Codes (genxguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by genxguy »</TD></TR><TR><TD CLASS="quote">A bit confused..
I got this:
which would suggest my '03 EX coupe with the VTEC 127hp 1.7L engine is a D17A2... but according to your list, mine is actually an A1. Also, isn't VTEC-E the engine for HX?</TD></TR></TABLE>
I got this:
