EDM EG Gauge cluster?
Ive been looking around a while for info/ picture of an European Doimestic Market gauge cluster for an EG with a speedometer that reads in m.p.h.
Does any one know if its any different than the USDM unit?(If it exists)
I remember seeing one on HT for an EF that had a speedo that read to 140mph from what I recal. I cant find the pic other wise I would link it.
Thanks!
Thanks!
Re: EDM EG Gauge cluster? (nosepkr)
I;ve been looking around for a new cluster for my 92 also...... here is the info i found:
i think the USDM EX/Si models had the tach that goes up to 9k and the spedo goes up to 140 (numbered to 120 only).
the JDM and "EDM" read in kph and went to 9k ad 190kph, and came in both black and white faces (SiR2 had white i believe). You can find them almost anywhere that sells JDM engines i do believe, or look in the classifieds to see if there is one up for sale. If I am wrong, someone pelase correct me, as i would liek the correct info. also!
MIKE
MIKE
Re: EDM EG Gauge cluster? (neonxrt)
Thanks, I allready have a JDM SiR cluster. I need one that reads in mph for when I move back to the U.S. I want one that has numbers all of they up to 140mph. I guess ther is no such thing
Maby ill just save my pennies and score one of these.
well, the cluster does go up to 140, it is just numbered to 120. that cluster is bad ***! how much $$$$$? is it a direct fit to the EGs?
MIKE
MIKE
That reminds me of my GF's dad's car. He got a caddy CTC. The onboard computer in that car is soooooooooo amazing. I bet you can play video games on it!
[Modified by charjacq, 5:11 PM 1/4/2003]
Yes, you can. If you can get one from a Civic VT-I (I believe, which is called the SIR-2 in Japan) that reads up to 9k with a redline of 8200 RPM's. The speedo will read like the US ones (reads at 120 mph) with toping out of 140. However, its not like the JDM that have white background faces. The EDM are just as standard black as the USDM. A friend of mine pick one up in England and is using it on his car. I'll see if I can find some pics.
Re: EDM EG Gauge cluster? (SANBST)
Yeah pics of the edm unit would be kick ***. Im still looking for some myself so if i find them ill link them.
The Stack unit above has a kit for civics I believe. I dunno how it all plugs together or if the kit even fits good. It would be a good way to kill many birds with one stone though because it incorperates every gauge you can think of. Maby even in the long run (instead of buying all of the gauges seperately) it would be cheaper.
If you would like to check out its features heres there website. http://www.stackinc.com/
[Modified by nosepkr, 9:31 AM 1/5/2003]
Scorchin Civic
16
10-15-2009 07:36 AM
