Which ECU to use for D15B engine??
Old 09-08-2005, 02:03 AM
Plum_civicEK's Avatar
Default Which ECU to use for D15B engine??
what ECU should i use for a 96-00 EK3 D15B engine????
btw, i'll be swapping it into a year 00 EK hatch :D
Old 09-08-2005, 08:14 AM
Default Re: Which ECU to use for D15B engine?? (Plum_civicEK)
up
Old 09-08-2005, 08:18 AM
Vero's Avatar
is this the JDM d15b vtec? If so use a p06 with an OBDII-to-OBDI harness.
for emmisions, you might have to run the 96-00 EX ecu, since that is a sohc vtec ecu.
Old 09-08-2005, 08:40 AM
Ace0246's Avatar
the obd2a route (what your car is wired for at the moment): a P2E would be your best bet. it's out of a 96-98 civic or 96-97 del sol S. if you don't have VTEC, it would be your best option. if you DO have a D15b VTEC engine, you should be able to run in on a D16y8 computer - which would be a P2P.
the OBD1 route: a p06 ECU will not control VTEC. if you have a JDM D15b VTEC engine, I would try your luck at sourcing a P08 ECU, or at least using a P28 and chipping it with a factory P08 program. if you don't have a VTEC engine, a p06 should work ok. jumper harness will be necessary no matter which way you go. .
edit: there may be an issue with a knock sensor if the D15b doesn't have one. might have to go OBD1 for the best result and no CEL's.
Modified by Ace0246 at 12:03 PM 9/8/2005
Old 09-08-2005, 09:13 AM
T-RO's Avatar
if you have to use the P06 just add the Vtec components
Old 09-08-2005, 06:53 PM
Default Re: (T-RO)
it's a JDM D15B engine from 96-00 civic in JAP and yes it's Vtec. The Y8 Vtec is different from the D15B since D15B is running 3 stage vtec and i'm wondering what's the different between the 3 stage vtec and the Y8 vtec????????
sry about the newbie question
Old 09-08-2005, 06:59 PM
Zeus Zore's Avatar
Default Re: (Plum_civicEK)
if its a D15B 130 HP JDM ****.. it needs a P08... that is the stock ecu.,.
Old 09-08-2005, 07:03 PM
Vero's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Plum_civicEK &raquo;</TD></TR><TR><TD CLASS="quote">it's a JDM D15B engine from 96-00 civic in JAP and yes it's Vtec. The Y8 Vtec is different from the D15B since D15B is running 3 stage vtec and i'm wondering what's the different between the 3 stage vtec and the Y8 vtec????????
sry about the newbie question</TD></TR></TABLE>
obd2-1 harness + p08 or 28/w chip for you then. Or p28 and run aftermarket management.
Old 09-08-2005, 08:06 PM
Default Re: (Vero)
so P08 is the code for the D15B engine right???
but is that the one for EK or EG, coz i'll be getting the one from EK not EG :D
Old 09-08-2005, 08:09 PM
RIP 1032
life sux die's Avatar
p08 is the ecu.
Old 09-08-2005, 08:21 PM
Jim Truett's Avatar
Default Re: (life sux die)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by life sux die &raquo;</TD></TR><TR><TD CLASS="quote">p08 is the ecu. </TD></TR></TABLE>
Only for the OBD-1 '92-'95 version.
He has two VTEC solenoids, which most refer to as three stage VTEC.
I would use a P72 or modified P28 with IAB enabled to run this motor. I would hijack the IAB control to actuate the the first stage at 2200 RPM, going from 12 valve operation to 16. Then at 5000 I would use the VTEC output to switch to the VTEC lobe on the intake cam. I recommend starting with a OEM P08 map and wideband tuning it to that engine. I have yet to see the proper OBD-2 ECU here in the states.
Good reading: http://www.pgmfi.org
Old 09-09-2005, 01:12 PM
Default Re: (Jim Truett)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jim Truett &raquo;</TD></TR><TR><TD CLASS="quote">
Good reading: http://www.pgmfi.org </TD></TR></TABLE>
i totally don't understand what you talking about, since i'm a newbie at this, guess i'll be facing a lot of trouble if i'm going to get this D15B, should i just go D16Y8??? what are the different between the Y8 and the D15B anyways? which one is better??? o and btw I'm located in Canada, Vancouver if that's matter
Old 09-09-2005, 02:29 PM
spoonek4's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Plum_civicEK &raquo;</TD></TR><TR><TD CLASS="quote">i totally don't understand what you talking about, since i'm a newbie at this, guess i'll be facing a lot of trouble if i'm going to get this D15B, should i just go D16Y8??? what are the different between the Y8 and the D15B anyways? which one is better??? o and btw I'm located in Canada, Vancouver if that's matter </TD></TR></TABLE>
Yea u should stick with local engines to avoid more headaches. It's just easy to get a Y8 swap or long block here & everything will pretty much go plug & play. Spend some other $ on getting timing belt service done, & put in new clutch & flywheel etc instead. A 92-93Si tranny with 4.25 FD would give u more difference than a JDMMMMM D15B block......IMHO
Why go D15B for the bling bling JDM title!?
Old 09-09-2005, 02:48 PM
FalkenSiR's Avatar
Default Re: (spoonek4)
P08 is not the ecu. This engine was also made 96-00. We all know the 92-95 D15B ECU is P08, but the 96-00 is ??? i don't know The only thing I know is that it came in 4 door ferios. I've seen them
Old 09-09-2005, 03:31 PM
93CX's Avatar
Default Re: (fast88std)
the D15B has a very agressive cam that creates that high bhp rating, but in general
1.6L &gt; 1.5L
Old 09-09-2005, 04:08 PM
dantastic's Avatar
http://asia.vtec.net/article/d15b/
good luck sourcing the jdm EK d15b w/3-stage vtec. it really isn't a performance motor..... it's really meant to be fuel efficient and technologically innovative. just stick with a d16y8. you'll save yourself a lot of headache and wind up making more power. heck, just swap in a b18b. it'll barely cost more.
Old 09-09-2005, 04:44 PM
FalkenSiR's Avatar
Default Re: (dantastic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dantastic &raquo;</TD></TR><TR><TD CLASS="quote">http://asia.vtec.net/article/d15b/
good luck sourcing the jdm EK d15b w/3-stage vtec. it really isn't a performance motor..... it's really meant to be fuel efficient and technologically innovative. just stick with a d16y8. you'll save yourself a lot of headache and wind up making more power. heck, just swap in a b18b. it'll barely cost more.</TD></TR></TABLE>
he does have a good point. IT IS RARE, but what's really the point?
Nicaraguense13
01-24-2017 01:35 PM
Bacondoggy
10-08-2009 04:14 PM
iceman7329
04-25-2007 10:08 PM
xtremelyloud2001
06-23-2004 04:00 AM
tr4il
11-25-2001 11:38 AM
Quick Reply: Which ECU to use for D15B engine??
