ECU question
ECU question
Im student in the GM training Center, i got the oportunity to flash my ECM but i want to know if this is posible in a Honda Civic 93 EX with D16Z6 Engine, and someone knows the values for the new ECU? or maybe the way to flash in the right way? thanks
Solbros Owns Me
Re: ECU question (Knight2000)
are you talking about flashing the codes?? Like 23= knock sensor or whatever??
If so, get the service terminal down from the ECU-held up by a clip or plug, and turn on your ignition. Stick either a piece of wire or a paperclip in one terminal of the plug, and the other side of your testing object in the other terminal of the plug. The check engine light will start flashing. A fast blink counts as 1. And a held out flash, counts as 10. There will be a pause betwen codes, unless you flash the same code over and over. Search on here or google to find out the codes. I don't want to.
new_climber
09-15-2009 09:22 PM
Niskyspy
13
03-10-2008 05:54 PM
crxzc
06-17-2002 03:37 PM
