ecu legality question..PLEASE HELP>>
ok i have just swaped a b18c1 in my 99 4door civic and i need to get this thing to the bar asap, and its running like **** with the ecu i have in it now, but any wayse i have an obd2a p72 ecu for a 99 b18c1..i have a 2000 b18c1 WILL THIS IF INSTALLED PASS THE BAR?
the shop i had the swap done at is telling me no. and they are telling me i need $200 more dollars to get the computer that was origanally going to go in the car....WTF..... they said it needs a key and they need to take it by acura and have it programed. i think im getting yanked. if so please tell me. and please tell me if the ecu will pass bar.
Re: ecu legality question..PLEASE HELP>> (camp_kill_yourself)
Theres is an immobilizer (sp?) in 99-01 ecus, so if you put the ecu in and cant start the car then yes you wont pass. Now if you put the ecu in and the codes work and everything fine, go down to autozone and rent an OBD2 scanner and see if it reads the code. If it does your go to go.
Re: ecu legality question..PLEASE HELP>> (Luserkid)
damn ok i have an ecu from an si that is chiped to work for my car and its 0bd2b so i will need to change wireing harneses and if it doesnt work. then change them back. ive never messed with that stuff should i do it my self or pay?
Why not switch to OBD1, most of honda's tuning programs are for 1 and not 2 anyways... and it should get rid of that pesky problem... and the shop for that matter.. as there's guides everywhere on how to do it...
-D
-D
For CA State Legal BAR, You will need the ECU that came originally in USA with that motor. Example, if you put a '99 B18C1 into your car, you will need the ECU that was avaliable in the '99 Integra GSR. Not your original one. You can't use OBD1 either, it is very specific to the year (same as or newer) and every little emissions thing has to be hooked up correctly. Good luck.
Re: (axtran)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by axtran »</TD></TR><TR><TD CLASS="quote">For CA State Legal BAR, You will need the ECU that came originally in USA with that motor. Example, if you put a '99 B18C1 into your car, you will need the ECU that was avaliable in the '99 Integra GSR. Not your original one. You can't use OBD1 either, it is very specific to the year (same as or newer) and every little emissions thing has to be hooked up correctly. Good luck.</TD></TR></TABLE>
ok so just to make sure. right now i have a 99 civic with a 2000 b18c1...there for i want an ecu for a 2000 integra. which is p72....
now i am setup for obd2b will this ecu work for my car and the state bar...
http://cgi.ebay.com/ebaymotors...QrdZ1
FliiBoii
26
11-23-2011 12:43 PM
