ECU Fried
ECU Fried
Have a eg8 with a JDM D15B and had it running on a p28. The other day I was parked idling and the car just died and saw smoke coming from the area where the ecu is. So I opened up the ecu and found this:
There is a large capacitor next to the B plug that burned up. I replaced the ecu with a P08 I had. The car seems to run fine till I've been driving it around for more than half an hour it starts to bog out. I'm concerned that this ecu is gonna fry next and the bogging is annoying. No cel's. Inspected all the wiring near the ecu and fuse box area yesterday and didn't find anything wrong. Any suggestions on what is causing this issue
Thanks
Mike
Thanks
Mike
Seagull Management
Re: ECU Fried
The electrolyte in the capacitor dried out due to being 17+ years old and the cap shorted. If you're handy with a soldering iron you can simply replace the cap and bridge any burnt traces. It wasn't caused by anything other than old age.
Re: ECU Fried
I'm not concerned with repairing the burned ecu it's that my car is bogging out with the new ecu
I've used the ecu in the past and it ran fine. Maybe I have to reset the timing?
Location: Pensacola, FL and every Court House in Louisiana
Re: ECU Fried
The title of your thread would make you think it was hence the reason I came in!
Car is bogging out with the new ecu... would of been more appropriate.
The Grumpiest
Re: ECU Fried
Which P08 do yo have? According to info out there, there is the one that runs the D15b that is the VTEC-E and the D15B VTEC that utilizes the small case P08.
The Grumpiest
Re: ECU Fried
So I'm going to have to assume it ran fine with the P28 since you failed to mention that in the OP. Have you checked timing? I'm not sure this is the case because the running rough after about 30 minutes thing is throwing me.
lsjon
Engine Management and Tuning
05-30-2008 08:41 AM
blu3g
07-19-2006 05:33 PM
_HANS
06-13-2004 03:33 PM
