ecu code #19 on 93civic help !!
ok, i have a 93 civic, with a problem,my car is showing the code 19, from what ive found, it "automatic selenoid" ? but my car is a 5speed, and i already check and it does have a p06-L5x ecu,
btw, since this started, mky car wont rev past 3k maybe 4k, not very sure since i dont have a tach.
any helph would be apreciated, thanks in advance..
Re: ecu code #19 on 93civic help !!
well thats a good starting point. the impact from the rear more then likely jarred something lose under the hood, or broke something. that code isnt very common in my experience, but ill look around and see what i can find
If you really want you could switch the ecu to a 5speed to get rid of the cel. all you need is a desoldering and soldering iron and a little patience
