ECU clicks and engine hiccups, HELP
MAIN RELAY not ECU clicks and engine hiccups, HELP
See new thread https://honda-tech.com/zerothread?id=2082474
update:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Relic1 »</TD></TR><TR><TD CLASS="quote">the main relay sits right above the ECU in your car. make sure it's not that.</TD></TR></TABLE>
ok so further investigation reveals taht the clicking is coming from a location above the ECU, so it appears that this main relay is the issue.
So is this something I will need to replace to fix, or is there some other trick?
--------------original post-----------------
I have a 96 DX Civic hatchback with a D16y7 from a '00 civic DX in it.
I am using the wiring harness, ECU and distributor from the 96 engine.
So when I am driving the engine will hiccup, almost like a quick little stall, at the same time there is an audible click, like a short or static zap, happening in the ECU.
Any ideas?
Modified by MonkeyPuzzle at 11:12 AM 8/28/2007
Modified by MonkeyPuzzle at 11:24 AM 8/28/2007
update:
Any ideas?
Re: ECU clicks and engine hiccups, HELP (MonkeyPuzzle)
one, more piece of information, this only happens when accelerating, does not happen when the car is idling
All Motor Mentor
1 Post
Check your ground wires, specifically the ones that attach to the thermostat housing. If they're even slightly loose, it will cause your car to do exactly what you're describing. The ground wires there are for your ECU so if the ground isn't good it's like switching your car/ecu on and off quickly. The clicking sound you hear is from your main relay switching on and off.
Re: ECU clicks and engine hiccups, HELP (00Red_SiR)
Checked my grounds in the engine bay and cant see any problems, any other ideas?
All Motor Mentor
1 Post
So you're saying that they're tight and the surface is clean and not corroded? Just make sure they are tight ( on the thermostat housing), sometimes a visual inspection only looks tight but when you put a socket on it, you find out it's not.
i dont know about the clicking from the ecu but when you swapped our motor did you adjust your timing at all... time to bust out the timing light would be my suggestion
Re: (Relic1)
will check that too, thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LessRice »</TD></TR><TR><TD CLASS="quote">i dont know about the clicking from the ecu but when you swapped our motor did you adjust your timing at all... time to bust out the timing light would be my suggestion</TD></TR></TABLE>
dont believe I touched the timing, but I think I would enjoy trying my hand at timing
Re: (Relic1)
replace = plug-and-play ~$50 new, ~$25 used
repair - http://www.marklamond.co.uk/te...y.htm - free if you can solder.
All Motor Mentor
1 Post
Re: (MonkeyPuzzle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MonkeyPuzzle »</TD></TR><TR><TD CLASS="quote">
Remember, a bad ground will also cause these exact same symptoms...
Chopstikz
01-11-2008 07:10 AM
DaX
04-24-2007 12:38 PM
