ebay turbo kit
ebay turbo kit
ok so i really want to turbo my ej8 but i dont have a whole lot of money so i was just thinking of getting an ebay turbo kit...i know there probably not the best but what do yall think?
Re: ebay turbo kit
there are going to be a lot of people try to steer you away from these kits because of the expression "you get what you pay for". And it is sorta true. I have had many friends use these with no problems and others with nothing but problems. Just buy from a reputable seller and you should have no problem
Re: ebay turbo kit
Yeah i kinda live by that expression too but i just dont wanna spend a bunch of money when i dont have to. What kind of problems did your friends have?
Re: ebay turbo kit
The main problem what the manifold. I had to reweld about 5 of them and brace them a little bit. The others were the turbos were very finaky. sometime there thrust bearings would last 2 years with some abuse and other times I was rebuilding them after a month and thats no fun to rip off a turbo that you just put on a month ago. Just remember there is a lot involved in turboing a car. It all the little things, such as doind the oil lines and getting a kit where the DP actually bolts to the turbo and and to your original exhaust. So plan on having that welded. And most of importance is the TUNE
Re: ebay turbo kit
yeah i know what all goes into a turboed car and i would most def get a good tune.
Re: ebay turbo kit
my buddy has ebay turbo kit.had it bout a year now. its a full sport jdm. so far 1 problem. the inlet on oil feed line is too big therefor blowing oil seals. simple fix, a restrictor . BUT i ordered the exact turbo kit about 2 weeks ago and the feed line came with a restictor sized at 0.5mm which eleminates the blown oil seals. i ordered from Iloveil TACO TACO.
this is the exact kit we have. anybody else come across any other problems ??
http://cgi.ebay.com/ebaymotors/92-00...Q5fAccessories
Re: ebay turbo kit
See not all people have bad things to say about ebay kits. And I have bought stuff from ilovetacotaco as well and he is a very reputable seller on ebay
Re: ebay turbo kit
I am pretty sure I had to cut off the turbo side flange from the downpipe on that kit to clock it like a 1/4 inch so it would fit a buddys car but thats it.
Re: ebay turbo kit
have you had any other fitting problems?
Re: ebay turbo kit
well the turbo cleared the block. intercooler piping was right. and downpipe hooked up ok because it does have flex pipe and is able to bend a little. but i think ima take it to get rewelded because it hangs a little low under oil pan and im afraid of bottoming it out and putn a hole in it.
Re: ebay turbo kit
Thats about it man those are the most frustratin things too because you think you have it done and you have to get something rewelded. But all in all to have something rewelded and maybe you will get lucky and have it all fit right up. That compared to a 3000 dollar kit you have a pretty good deal IMO. Not to a hipocrit but I used a treadstoneperformance on mine because it is way better quality for about 1700. You get the turbonetics turbo of for a little less they can set you up with a really nice garret, but its up to you and how deep your pockets are.
Re: ebay turbo kit
yeah i was thinking about that one cause i mean i have a job ill just need to save up for it...how much does it usually cost for a good tune
Re: ebay turbo kit
well seeing as how your obd2 your going to need a obd2 to obd1 conversion harness and obd1 ecu plus someone to do the actual chipping of the ecu and then the tune
conversion harness=55 on ebay
ecu chipping=75
ecu depending on which one you get=50-120
base tune xenocron=25
base tune local=50 better
dyno tune= 100/hour recomended
ecu chipping=75
Re: ebay turbo kit
I would highly recommend buying either a Treadstone kit, or from Spoolinperformance....
Ebay kits are tempting, but just not worth the risk.
I would look in the Forced Induction FAQ... There is an extensive thread on this.
Intercooler kit = ok
Manifolds = crap
Wastegate = not worth the risk
BOV = ok
Turbo = some ok on low boost, some crap either way
Fittings = cheap steel, most seem to work
Honestly, I wouldn't buy drag or peakboost either. I personally will be buying everything from Spoolinperformance. Add it up, it's around $1800 for everything. I also like that you can have the closed loop dumps pre-fabbed. Their parts are quality!
Manifolds = crap
BOV = ok
Re: ebay turbo kit
SEARCH!!
You need to ditch the FMU, get some larger injectors, get a Chipped ECU, and go to a tuner.
Chipped ECU's are a stock ecu that has the ROM chipped replace with a female socket. This allows tuners to create a custom tune for your car, and place the newly programmed chip in your ECU. There are many options.
http://www.xenocron.com/install/Intr...CUChipping.htm
Re: ebay turbo kit
not to bash spooling but I had bought one of there 600 dollar stainless logs for a b series and I probably put 4 hours into welding in because the wastegate was way off and so was the downpipe
Re: ebay turbo kit
This item is produced for off-road or show purpose only. This item is not suitable for regular driving. User must follow the direction given and any misuse of this product is at his/her own risk. The Manufacturer, Distributor, and retailer will not be held responsible for using this item other than specified above."
Doh!
Re: ebay turbo kit
im not asking bout a turbo kit i have one. i put an fmu on it as most people do because they cannot afford a tune at the time. im looking into a tune and wanting to know exact what you all think i should do because i dont have money to fool around and mess up. which is why my car is parked for now so i dont blow it waitn on tune. but when i do drive it i run it rich.
