Easy fix for broken clutch sensor depressor?
Hello All,
I have a 1993 Civic Si - the had been sitting for a while got it running again. The problem I am having now is the "clutch engaged and clutch disengaged" little plastic bumpers back underneath pedal that pushes in sensor to allow car to start have broken. I experienced same with brake pedal sensor not too long ago and was able to do a fix myself with a little jerry-rigging. With the clutch pedal I can only get one finger into that area at best. So it is going to be exponentially harder to do a "fix" on it. Should I remove pedal? Can I bypass the safety switch? Does anyone suggest a fix for this issue?
Thanks in advance,
SiCivicHB1993
Thanks in advance,
SiCivicHB1993
Re: Easy fix for broken clutch sensor depressor?
The easiest way I found to shove the stopper in the hole is to use a piece of wire to guide it into the hole and a flat bladed screw driver to shove it in. And you really do need to shove the driver seat all the way back or remove it.
Thanks for all the help gents! I removed the front seat earlier as I had the same issue with brake bedal sensor/stopper pad whatever the heck it's called. But the clutch is even more restricted access. I was finally able to get a couple of local parts company guys to understand what i was talking about. One wanted 4 bucks for an assorted pack (which none may have fit it) and the other guy said yeah I can get one in for 8 bucks! I'm sorry but 8 bucks for essentially a plastic thumbtack just isn't cutting it. But maybe I will pay for it just to get it back on the road - I would do a "ghetto fix" cuz it's just not that essential for what it does, but the space is soooo limited! Ugh...Thanks for the ideas guys!
PS - I suppose this is actually good news after pulling starter to test it and check battery and all fuses and connections with multimeter but I almost feel like replacing starter would of been easier after pulling and reinstalling it - actually i KNOW the starter would of been easier - I must find a friend with tiny tiny hands!
sicrx69
54
03-20-2015 04:22 PM
