Early Redline
Early Redline
95 civic ex d16z6..replaced old d16z6 with another and this happened .low low idle low pressure at the tip of exhaust...redline just over 6grand???didnt pass smog and i feel like engine isnt as strong...
Last edited by Former User; 08-08-2012 at 03:53 PM. Reason: Post clean up after redirect
Re: Early Redline
I don't know your mechanic. I just know that it's not uncommon for mechanics to get it wrong. And if you have complete trust in your mechanic and wish not to question his diagnostic skills, then get your car to him ASAP.
It just seems that you already know what the solution is and is not. In this case, a tech forum like this can't convince you to think otherwise. Pay your mechanic to fix your car.
Re: Early Redline
i dont have to pay him... and i came here for advice from others who shared the problem, i dont know what is causing this problem,,if i did i wouldnt have posted.....
Re: Early Redline
You say you want advice but you reject suggestions and make huge assumptions. Nobody can tell you what the problem is unless you start checking things suggested to you. Otherwise, you are asking people to guess based on symptoms that can have many different causes.
If you can't or won't inspect things or do some tests, then you really should just pay your mechanic.
deafspanky
09-12-2012 04:10 PM
