Dying [email protected]#
Old 05-21-2010, 12:38 AM
eg grom's Avatar
Wuddup Fellas,
Been workin' on the ol' eg hatch for quite some time now and I'm slowly runnin' out of ideas as to what the hell is causing this thing to die out.
So here's the run down:
- Throttle response is seriously lagging throughout every gear upon acceleration
- Quickly loses acceleration going uphill forcing me to downshift in order to get up the damn thing
There is no CEL. I have cleaned the IACV, cleaned the throttle body, checked the ignition timing, replaced the distributor, rotor button, spark plugs, spark plug wires, air filter, catalytic converter and pressure tested all 4 cylinders. The only thing I can think now is that it has something to do with the fuel system. Does anyone have any idea as to what is wrong with this damn thing?
eg grom is offline
Old 05-21-2010, 06:08 AM
Default Re: Dying [email protected]#
the lil engine that cood that needs boost =o)...maybe change the fuel filter
apexi_rsx is offline
Old 05-21-2010, 06:22 AM
tlarimer's Avatar
Check all components on the fuel system. Replace fuel filter, check FPR, injectors. What color are you spark plug tips?
tlarimer is offline
Old 05-21-2010, 07:33 AM
jdmh22eg2's Avatar
i say make sure ur tps is with in spec on the 5v wire a small amount out can make a diff
altho i higly doubt this is ur prob
u said u did a comp test what were the #'s
jdmh22eg2 is offline
Old 05-23-2010, 02:10 AM
eg grom's Avatar
Huh, the little engine that could...
Fixin' to be workin' on a boost build , but I'm Saving up for some good internals.
- I'll definently look into replacing the fuel filter and do a thorough check of my fuel system components.
- I have checked the injectors and they sound as though they are running fine. The spark plugs are 4 prong and do show some wear, but no odd burns or carbon build up.
- Not sure how to check the 5v wire on my tps, but would like it if you could send me some more info eg2. The comp test came out with some variations on each cylinder, but all well within spec.
eg grom is offline
Old 05-23-2010, 08:15 AM
95civtecex's Avatar
just a thought but when did you or have you replaced the cat converter? my bro had this same problem on his bronco he replaced the cat an runs perfect i kno his is a v8 an we all have 4 bangers but hey you never kno
95civtecex is offline
tacorunner87
14
01-03-2009 09:05 PM
vietintegboi
10-16-2006 02:10 AM
93slmdcvcsi
17
11-01-2003 09:46 AM
thehondaguru
11-21-2002 12:02 PM
whagkangmakulet
10-02-2001 05:57 PM
Quick Reply: Dying [email protected]#
  • Ask a Question
Question Title:
Description:
