dx trans will not go in gear just put in clutch
my dx trans will not go in gear with the car on, it goes in fine off, and it grinds really nasty if i try reverse it was put together right only goes one way
so could it be the clutch master
feel free to ask Q's i want this resolved
Re: dx trans will not go in gear just put in clutch
i think it has something to do with the clutch fork not being able to release it enough to go into gear and the only reason it does go into gear when your moving is cause of syncros so either it needs to be bled more or a new clutch master to push the clutch fork more. anyones thoughts
Does the clutch pedal feel spongy or is there no resistance when pushing it? If not, you might want to check whether the clutch fork is broken/damaged/worn where it meets the slave cylinder. You also might want to try adjusting the clutch pedal.
old_school_dohcvtec
10-04-2007 09:47 AM
VTECVillain
03-31-2003 07:44 AM
