Dumb question.
Dumb question.
I know this might seem like a dumb question but what engine does a 97 Honda Civic Si come stock with???? I am in Canada so I believe the Si is the same as the (US) EX. I also think that it is a 1.6L SOHC. I would also appreciate knowing the engine serial number since you guys use the serial number on the forum
I searched the topic and couldn't find anything on it.
PS- What is the horse power for that stock engine and is it a SOHC?
Thanks guys.
Thanks guys.
Re: Dumb question. (Konig)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Konig »</TD></TR><TR><TD CLASS="quote">I know this might seem like a dumb question but what engine does a 97 Honda Civic Si come stock with???? I am in Canada so I believe the Si is the same as the (US) EX. I also think that it is a 1.6L SOHC. I would also appreciate knowing the engine serial number since you guys use the serial number on the forum
Thanks guys.
Disregard guys. I found a chart with the specs.
Specifications: (1996 - 2000)
Civic Coupe EX (Canadian Si)
Displacement = 1590
Horsepower @ RPM = 127 @ 6600
Torque (lb.-ft. @ rpm) = 107 @ 5500
Compression Ratio = 9.6:1
Valve Train: 16-Valve SOHC = VTEC™
0-60 mph = 8.5
1/4 Mile = 16.6/83.7
There is one question that still remains what is the correct engine code(serial #) for this engine and are the specs that I found accurate???
Thanks guys.
Displacement = 1590
0-60 mph = 8.5
Re: Dumb question. (Nihonjin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nihonjin »</TD></TR><TR><TD CLASS="quote">d16y8. i think it's rated at 127hp. yes, it's a SOHC. </TD></TR></TABLE>
Thanks, You snuck this post in while I was writting my own answer up
honda_tuner10
11-06-2006 06:32 AM
