Duh! Where is the coolant bleeder valve?
Old 04-19-2006, 05:30 AM
nota-eg's Avatar
Default Duh! Where is the coolant bleeder valve?
I have a 95 civic w/ a D16Z6. I checked my coolant the other day and noticed it was low. I filled it back up and went to bleed the system to make sure there was no air in the system.
Got out a 12mm socket, went over to the thermostat housing and BAM! Nothing. I checked my manual and the only picture they had was of it right there by the thermo housing.
So, can I get a picture of where the bleeder valve is? On my friend's F22 it's on the back of the block on the thermo housing, so I know what I'm looking for, I just can't find it.
Also, is there a possibility that my car doesn't have a bleeder valve?
Sorry for the tard question.
-Nick
Old 04-19-2006, 05:37 AM
djsire's Avatar
Default Re: Duh! Where is the coolant bleeder valve? (nota-eg)
fallow the top radiator hose to the motor. you see where it connects. right on that connection will be a lil nut with a nipple. loosen that till all the bubbles come out.
btw your car has to be warm for the collant to actually flow throuhg the top tube.
tell me if this helps
Old 04-19-2006, 05:42 AM
nota-eg's Avatar
Default Re: Duh! Where is the coolant bleeder valve? (djsire)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djsire &raquo;</TD></TR><TR><TD CLASS="quote">fallow the top radiator hose to the motor. you see where it connects. right on that connection will be a lil nut with a nipple. loosen that till all the bubbles come out.
tell me if this helps</TD></TR></TABLE>
I appreciate the help. I know how to bleed the system by letting the car warm up, thermo opens, bottom hose gets hot, ect, ect (how I had to do it because I couldn't find that stupid valve. )
I just want to find that damned bleeder or have someone tell me I'm not completely nuts and that there's a chance I don't have one. I'll have my friend try to find it when we're doing my clutch swap tomorrow.
I mean, it's hard to miss the nut. It's a 12mm w/ a nipple on the top of it. Only nut like that in the entire bay (that I'm aware of).
Old 04-19-2006, 06:08 AM
2lua's Avatar
some cars do have it and some cars don't
Old 04-19-2006, 06:10 AM
nota-eg's Avatar
Default Re: (2lua)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2lua &raquo;</TD></TR><TR><TD CLASS="quote">some cars do have it and some cars don't</TD></TR></TABLE>
Thank you. More or less what I was hoping to hear so now I don't think I'm going completely nuts.
If I could get a picture as to where EXACTLY it should be on a Z6 I'd really appreciate it.
Old 04-20-2006, 10:52 AM
djsire's Avatar
Default Re: (nota-eg)
the other way ive been bleeding it is to run the car with the cap off for like 10 15 minutes
Old 04-28-2015, 03:51 PM
GDD's Resident Derp
W95civicEXcoupe's Avatar
Hey! I found it.
White_EG1
09-18-2016 11:41 AM
TeknoGodz
04-19-2015 11:30 PM
Acidcrakker
12-09-2007 04:14 PM
Quick Reply: Duh! Where is the coolant bleeder valve?
