dseries oil pans interchangeable?
Ok,
i've got a d15b7,
and have most of the parts for a turbo kit,
dont have as much time in my life as I used to,
so i cant really spend all the time needed to do everything myself
SOOO, I want to find a used oilpan thats already been tapped, and just swap it in.
now I saw some on ebay, but its alot easier to find one from a different engine,
one going for a d16y7 right now for example.
so i'm wondering, what dseries engines can I trade oil pans with?
thanks!
i've got a d15b7,
thanks!
Re: dseries oil pans interchangeable? (nsxmatt)
anyone know a good idea on how to remove the old gasket off of the pan? mine is all stuck and wont scrape off...
Re: dseries oil pans interchangeable? (Tad)
The D15 and 16 '88-'95 pans are interchangeable. The Y series '96+ bolt pattern at the oil pump end is different, but if you wanted to drill it, it should fit.
Re: (95turbohatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95turbohatch »</TD></TR><TR><TD CLASS="quote">Yes d series are interchangable..
I have done it..
bump</TD></TR></TABLE>
there ya go !
I have done it..
there ya go !
Re: dseries oil pans interchangeable? (Jim Truett)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jim Truett »</TD></TR><TR><TD CLASS="quote">The D15 and 16 '88-'95 pans are interchangeable. The Y series '96+ bolt pattern at the oil pump end is different, but if you wanted to drill it, it should fit.</TD></TR></TABLE>
ok sounds good.
1question though,
if I were to get a y pan,
would I need to drill into the block, or just drill a new hole in the pan?
i've got nothing against drilling a new hole in the pan, but I dont want to mess aroudn with the block.
ok sounds good.
1question though,
Re: (ShadyEH2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ShadyEH2 »</TD></TR><TR><TD CLASS="quote">you do know that Y pans are cast aluminum, instead of pressed steel, right?</TD></TR></TABLE>
correct
d16y8= aluminum
d16z6=steel
correct
d16y8= aluminum
d16z6=steel
i would also like to know. i have a d15b thats already drill ready for turbo. but imma swap my motor out and swap in a y8 can i use my d15b oil pan on the d16y8?
Re: (ShadyEH2)
Except D16Y7 oil pan; it is stamped steel.
You would need two new holes in the pan at the oil pump end, and you would need to grind or mackine a flat for the nut to seat on. Very easy if you have the right tools.
ok, so one is steel and the other is alluminum
does that matter?
if its just choice, then i'd rather have the illuminum.
but is there a problem using either one on whatever motor?
does that matter?
Re: (Tad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tad »</TD></TR><TR><TD CLASS="quote">ok, so one is steel and the other is aluminum
does that matter?
but is there a problem using either one on whatever motor?</TD></TR></TABLE>
92-95 All oil pans are the same.
96-00 Non-vtec are stamped steel and have different bolt pattern than 92-95
96-00 Ex and HX use a aluminum pan of same bolt pattern.
Maybe they used aluminum on the VTEC motors to make the bottom end a little stronger.
does that matter?
