dropping steering column
changing my dashboard puttin in a Si
92 hatch cx to 93 Si hatch
need to know how to drop steering column so i can pull dash
any help plz
any help plz
Re: dropping steering column (spgcuantik)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spgcuantik »</TD></TR><TR><TD CLASS="quote">changing my dashboard puttin in a Si
any help plz </TD></TR></TABLE>
Remove the trim..
Look under the dash for the nuts. I think they are 12mm and down at the bottom there is a 10 mm. There is also a plastic trim piece around the column...
Just remove everything that is bolted or plugged onto the column.
Whats the dif in the 2 dashes you are changing?
Remove the trim..
Re: dropping steering column (E.Honda)
Carefull dont just go unpluging wires! Make sure you are not messing with any of the SRS wiring. if you do you risk setting off the air bag. Just make sur eto secure the air bad per the shop manual and you won't have any problems
Re: dropping steering column (instructor74)
just disconect the battery wait about 3 mintues so that anything that still has power can discharge. Or just touch the neg. pos. terminals off the battery that will discharge any current in the circuts. Continue on with removing whatever. Also make sure to keep your steering wheel striaght as possiable because your vehicle has a clock spring for the srs air bag. You can damage. So when you disconect the linkage from the guide pin from the steering rack hold it striaght or have a freind hold it until you can remove it out of the vehicle.
Timmyflys
10-12-2006 08:39 PM
DXDOHCVTEC
07-20-2004 09:09 PM
Eg_Lover
07-15-2004 04:50 AM
Nextelbuddy
06-22-2003 09:01 AM
