Dropped 2.25 - Fender trim - what to do?
Old 04-28-2003, 05:38 PM
AcuraEL's Avatar
Default Dropped 2.25 - Fender trim - what to do?
Hi guys, I need your help on this.
I've a 99 sedan, dropped with neuspeed race, konis yellows, khumo supra 205/45/16, the day I installed the springs, the thing was rubbing the underfender trims terrible, so I had to remove them. I want to know, is this a normal thing to do or there might be some workaround?
I though of cutting out the middle part of those trims , like where the top of the wheel would touch it and just leave the front and back parts, to protect the inside of door from mud and some of engine bay.
Your input is really needed on this. Thanks!
Old 04-28-2003, 05:44 PM
Rhythm Racer's Avatar
Default Re: Dropped 2.25 - Fender trim - what to do? (AcuraEL)
Your car is to low!!!
Old 04-28-2003, 05:49 PM
Pworld's Avatar
Location: somewhere in INGLEWOOD chillin in tha hood, CA
Default Re: Dropped 2.25 - Fender trim - what to do? (Rhythm Racer)
take trim out, roll fenders, u can do other ways but if u cut it, and for some reason it rubs u can cut the wheel....... some people have cut that lil lip on the fender off, used touch up paint, then use some kind of rust preventive coating(i think its called underbody spray), but i would put a lil piece of rubber on that just incase
hope that can spark some ideas.......but to do it right is have a body shop roll it or cut it
moondoggy's Avatar
either raise your car a bit higher or get smaller wheels
Old 04-28-2003, 06:14 PM
Ya@inlinePRO's Avatar
Default Re: Dropped 2.25 - Fender trim - what to do? (moondoggy)
i removed my fender thingymajig. plenty of people do that, but it does sent dirty stuff into the door jam behind it.
Old 04-29-2003, 02:18 AM
AcuraEL's Avatar
Default Re: Dropped 2.25 - Fender trim - what to do? (kwik2nec)
speaking about a little pieace of rubber, does honda sell it on some models? I remmeber seeing it already but can't remmeber where.
I was thinking of hiding the door jams somehow, maybe using a cut of pieces from the fender thingymagic
Old 04-29-2003, 04:17 AM
HT White Ops
BlackDeuceCoupe's Avatar
Sounds like you got the wrong offset on your wheels...
Old 04-29-2003, 11:58 AM
AcuraEL's Avatar
Default Re: Dropped 2.25 - Fender trim - what to do? (BlackDeuceCoupe)
offset is fine, it doesn't rub the fenders, it was rubbing the underfender plastic mud covers!!!
Old 04-29-2003, 10:39 PM
HT White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AcuraEL &raquo;</TD></TR><TR><TD CLASS="quote">offset is fine, it doesn't rub the fenders, it was rubbing the underfender plastic mud covers!!!</TD></TR></TABLE>
Oh, really? What's the offset?
96civicsd
Honda Civic (2006 - 2015)
18
09-02-2009 11:17 AM
uncleben
18
08-29-2008 02:45 PM
Yoshiod9
04-18-2005 08:10 PM
Finger Lickin' good
10-02-2004 06:53 PM
GM Killer
12
02-27-2002 06:06 PM
Quick Reply: Dropped 2.25 - Fender trim - what to do?
