Gauge Cluster Question
Old 04-09-2012, 04:00 PM
AlabasterSI's Avatar
Default Gauge Cluster Question
Hello everyone, I recently bought a 2000 Si with the intesions of putting a Itr motor in it. So being the very impatient person I am I bought the 98+ spec version with the lsd tranny and ecu and it's coming tomorrow. I obviously know that the Si an Itr gauges don't match up so does the ecu correct this and can i rely on my Si tach or should i buy a autometer tach.
Old 04-09-2012, 04:58 PM
EK9
Dc4LsTeG's Avatar
Default Re: Gauge Cluster Question
??? Your tach will read fine it just won't be perfect as OEM ones never are
Old 04-09-2012, 04:59 PM
been there done that
doood's Avatar
lol wat?
Old 04-09-2012, 05:02 PM
progekSiR's Avatar
yeah you lost me. your motor harness has absoulutely no affect on your cluster. lol
EK9
Dc4LsTeG's Avatar
He thinks cuz the motors are different the cluster wont read correctly lol
Old 04-09-2012, 05:04 PM
progekSiR's Avatar
lol hope that motor came with ecu or you better jump on the chipped p28 wagon
Old 04-09-2012, 05:05 PM
EK9
Dc4LsTeG's Avatar
Old 04-09-2012, 05:19 PM
ehrkeith's Avatar
Doing a swap but didn't know the cluster would still read?
Its all the same if it was a V6 you would have a problem but there is no difference what so ever, I don't think the computer determines what your tach reads anyways.
Old 04-09-2012, 05:23 PM
progekSiR's Avatar
^it doesnt. but if hes dropping a type R with the stock type R ecu the rpm wont read after 9-9.5 (cant remember what si cluster reads to)
Old 04-09-2012, 05:35 PM
beecee18's Avatar
Si is perfect canidate for 98+ITR swap,
ecu should be perfect other than being programmed for95 oc.
although LTFT will compensate for the most part.
Si cluster is fine and actually one of the coolest ones out there in my book.
9k-9.5k^^^^
yeah dude they have a factory fuel cut for that engine at 84-8700, Your good to go duder.
cinci00si
05-04-2009 11:20 AM
DCRB
10-10-2008 08:25 PM
ecasciaro
11-30-2007 09:02 AM
solpower
12
02-02-2006 07:51 PM
direct_connect
18
01-04-2002 04:58 PM
Quick Reply: Gauge Cluster Question
