Driver's side floor board soaked.... Ahhh
I have a 92 VX with 99 B18C1 swap which doesn't see winter and is garage kept. I have a winter beater to get me around. I get in it and start it up and drive it around once a week though. I got in it yesterday and noticed that my driver's side floormat creaked when I put my feet down I pulled up the mat and the floor carpet was frozen to the mat. It's been well below freezing for a month straight. My first thought was the heater core leaking, but if it were coolant it shouldn't be frozen. Looks like I'll be yanking the carpet completely out to investigate...
Re: Driver's side floor board soaked.... Ahhh (VTECVillain)
To be completely sure, yank everything out and do a leak test, you'll find the culprit soon enough. Had the same problem a couple of months ago, turned out it was a hole in the firewall area that wasn't plugged up. Good luck!
Re: Driver's side floor board soaked.... Ahhh (Benj)
I just removed everything this morning: seats, armrest, console, ebrake console, blah blah. Now it looks to me like the wiring going to the SRS computer won't let me get the carpet out. I think I need to disable the airbag and unplug the harness so I can remove the carpet Does anyone know what I'm talking about?
[Modified by VTECVillain, 1:57 PM 2/7/2003]
Re: Driver's side floor board soaked.... Ahhh (4g4me)
cut the carpet.
I had to cut my carpet in one little place where it goes around the center console, no big deal, i was able to hide it.
there have a been a billion posts on this, if you do a search you will find them all.
I think it came down to if you ever have had your windshield replaced, then the cowl wasn't installed correctly, or the sealing was not, then the leakage form that ill drip down during any wet weather and collect mostly on your passenger floor, and sometimes drivers. Most of the people, and me, cause i had it happen, said it was the passenger side, so you might wanna check that out too!
Re: Driver's side floor board soaked.... Ahhh (pkek)
Commiecircusbear
17
01-19-2008 05:23 PM
