Door wire passage?
Door wire passage?
Hey all -
Got a new stereo and speakers with an amp I'm going to be installing. The current setup has wires that come out from under the dash and are visible when the door opens.
How hard is it to run them through the same wrap that the rest of the electrical passes through? (Power windows/locks/etc) I want to hide the wires completely.
Car is a 95 Sol Si.
John
Car is a 95 Sol Si.
John
Re: Door wire passage? (OversteerMotorSports)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OversteerMotorSports »</TD></TR><TR><TD CLASS="quote">What happened to the factory wire setup? </TD></TR></TABLE>
Going with larger gauge wire from the amp to the front components.
John
John
Re: (Ron454321)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ron454321 »</TD></TR><TR><TD CLASS="quote">Its not too bad although I'm pretty sure when I did it I had to take off the fenders to get the clips to pop off.</TD></TR></TABLE>
Hrm. I'll probably wait until I have a week off from work in Nov to do it then. I'm not that quick yet
John
John
Re: Door wire passage? (Aodhan)
The only way to do it right is to re-pin the plugs with larger wire. Although you really don't need to. Just tap into the factory wires. You can't just run new wires through the rubber loom as there is a male and female connector on the door.
Re: Door wire passage? (E.Honda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by E.Honda »</TD></TR><TR><TD CLASS="quote">The only way to do it right is to re-pin the plugs with larger wire. Although you really don't need to. Just tap into the factory wires. You can't just run new wires through the rubber loom as there is a male and female connector on the door.</TD></TR></TABLE>
Will that work running for the crossover of components up front?
John
John
i did this in my setup.
there is a loom and plug in the door jam on each side. if you pull apart the harness you will see honda left alot of room for additional wiring if they wanted to pin it. I just drilled tiny holes through there, and then fed the wire through.
my car is an 00 civic ex (power doors and locks wired) so it may be different.
Re: (igo4bmx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by igo4bmx »</TD></TR><TR><TD CLASS="quote">i did this in my setup.
my car is an 00 civic ex (power doors and locks wired) so it may be different.</TD></TR></TABLE>
Might be, but probably not enough to matter. I'll take a look. Now I just have to figure out how to get it out and through the fender TO the passthrough.
John
John
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Aodhan »</TD></TR><TR><TD CLASS="quote">
John</TD></TR></TABLE>
yes..there are empty slots you can pin for mids...tweets.
You don't have to remove fender. feed the wires from the inside of car.
Tape your wire you wish to feed to a clothes hanger and don't force it through as you don't want to risk tearing the rubber sleeve.
I did this to my car....looks just like factory.
