dohc zc motor jdm d15b tranny axle help
i have a 94 honda civic with a dohc zc swap its automatic, i messed up the zc tranny so i bought a jdm d15b tranny from the jdm engine depot and everything bolted up perfect no problems but i went to go put my axles in and there jus not fitting. they fit in fine wit no problems wit the zc tranny but now wit the d15b tranny its like the axle head tht goes into the tranny on both the drivers and passengers side are too small, i took a b series axle and visualy compared the sizes and it looks to be the same size as a b series. anyone have this problem or know an answer please i need help thanks.
PHANTOM MENACE
Re: dohc zc motor jdm d15b tranny axle help
Not sure if it applies to hydro DOHC ZC specific transmissions but with cable DOHC ZC transmissions the axles are unique in that they use an intermediate shaft and equal length axles. If it's the same difference, then you'll have to use the unequal length axles that the Civic normally uses.
PHANTOM MENACE
Do your current axles have two equal length shafts and a half/midshaft? Or is it one long and one short axle?
My response had nothing to do with any ZC motor, it was a specific axle difference unique to the older DOHC ZC specific transmissions. From your first post:
It sounds like you tried to use your existing axles from a DOHC ZC full swap on a D15B transmission. This is why I posted what I did.
