dohc zc issues.
dohc zc issues.
to start, im putting a DOHC ZC in my 93 LX,.
somene told me, that i can use my d15b7 distributor and it will fit with 1 bolt on it and none of the holes line up in any way, what should i do about this, (its my daily driver so im looking for a quick fix for now, until i can get the right dizzy.)
which distributors will work?
also, the engine needs a timing belt ASAP. but i ordered a timing belt from the advance auto parts for a 87 integra, which comes with the d16a9 usdm version of zc right?
also, where can i get a power steering pump and bracket, and the AZ bracket for this? what car do i get it from?
ive been learning slowly that this is a bastard child of an engine and nothing will fit on it from other d series.
your help is appreciated thanks in advance
Seagull Management
Re: dohc zc issues.
The only complete bolt on distributor is an OBD1 DOHC ZC distributor, you can either buy a used JDM unit from an importer if they have one, buy a distributor king distributor on ebay, or build one with the ZC case and guts out of an OBD1 D or B-series distributor (you have to reuse the shaft, trigger wheel assembly from the ZC though)
IIRC thats the right belt.
Re: dohc zc issues.
You need to use the cam cap off a B18A1, it will let you get the top bolt in a D15B7 distributor, i've done it before, it works.
CRXguy_88
12
09-15-2010 12:42 PM
Speed_Ricer99
02-16-2002 05:26 PM
