DOHC ZC in Dx Eg
DOHC ZC in Dx Eg
Before anyone goes off and says buy a b16 or d16z6 hear me out. My buddy just picked up a 95 dx for dirt cheap. Anyway, i have my old zc motor out of my crx at the shop and we thought just for ***** and giggles since a motor swap only take and hour that we would through the zc in the eg because he needs to replace hi sInput shaft bearing. My question is do we use the eg mounts?? i know we will just use his intake manifold and exhast manifold just whihc mounts?? Just thought we would try a little project since we can.
Re: DOHC ZC in Dx Eg (dpw41285)
anyone?? i just found out i will have to use the zc mani with dx sensors and injectors, anybody see a problem with that??
Im not sure about the dx injectors on the motor seeing as its a DOHC and the dx is a SOHC but i dont know. The sensors i think you could use. Same with the mounts.
im pretty sure all stock honda injectors except prelude were either 240cc or 280cc. ah. its one of the two. everything should bolt right in except the coolant sensor. the ZC will have a coolant sensor on the back of the block whereas the obd1 95 dx will have the coolant sensor on the thermostat housing. you will need to lengthen the wires. everything else should be fine except youll be running some shitty tune from a dx ECU.
Circuit Star-29
02-12-2005 10:24 AM
FourthGenHatch
15
04-09-2003 12:07 PM
