This is for the DOHC guys. First time at the track w/the Turbo D16 sol.
Old 07-15-2004, 09:06 PM
racinskittle's Avatar
Default This is for the DOHC guys. First time at the track w/the Turbo D16 sol.
Just wanted to share w/the del sol guys and SOHC that come around here that I took my car to the track yesterday.
At 8.5psi. I ran a 14.3 @ 100.3mph. I beat a GSR hatch running 14.6 @ 97 on one of my runs as well. My trap's good for 13.2-13.2 on slicks. Ill be back in a few weeks lookin for high 13's on 10psi and street tires. Ill keep ya updated.
Here's the slip.
Just posted this so some of you del sol guys and SOHC can use this as a basis for the arguments I know you guys have all the time SOHC vs DOHC. THe battle will never end
Ah well, Honda's a Honda. RIGHT!
Old 07-15-2004, 09:09 PM
drewbie's Avatar
Default Re: This is for the DOHC guys. First time at the track w/the Turbo D16 sol. (racinskittle)
cool
I expect to hit maybe mid to high 14s when I swap my new final drive
Old 07-15-2004, 09:12 PM
skip.two's Avatar
nice time man. rep that D16 sol . that 60 isn't good though, work on it. post this in the 1/4 SOHC thread as well.
Si Erik's Avatar
Default Re: This is for the DOHC guys. First time at the track w/the Turbo D16 sol. (Mr. Teal)
Get your 60' down and you'll have a much better time!
Old 07-15-2004, 09:13 PM
articbluedc5's Avatar
Default Re: This is for the DOHC guys. First time at the track w/the Turbo D16 sol. (jL iLLuZiOnz 9)
Holdin it down for us, get those slicks I wanna see your times!
Old 07-15-2004, 09:17 PM
redline201's Avatar
Default Re: This is for the DOHC guys. First time at the track w/the Turbo D16 sol. (94CarbonHatch)
i bet w/ a 2.0 60 ft you would be in the high 13s without the slicks
Old 07-15-2004, 09:25 PM
wongf22b2's Avatar
Default Re: This is for the DOHC guys. First time at the track w/the Turbo D16 sol. (redline201)
How much are del sol's lighter than the teg?
Old 07-15-2004, 09:32 PM
Default Re: This is for the DOHC guys. First time at the track w/the Turbo D16 sol. (wongf22b2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wongf22b2 &raquo;</TD></TR><TR><TD CLASS="quote">How much are del sol's lighter than the teg? </TD></TR></TABLE>
lol
THANKS GUYS! I appreciate it
I can't wait to go back. Yeah those 60' times were crappy. I couldn't launch above 3000 b/c I had my full throttle launch at 3000 till 10mph. THAT SUCKED. But I was able to cut consistent 2.4 60' times
When I get back ill be lookin for only 2.3 60's It'll be my 2nd time at the track and im just starting to get the hang of it.
BTW just a little FYI: When I replaced the engine I reused the same headgasket. (100,000 miles and STILL counting) (hehe )
Old 07-15-2004, 09:34 PM
deeksmooth's Avatar
i don't know why you're throwing that in the face of DOHC'ers... thats not much weight to toss around. here's a link to a thread on hondavision.. its my old del Sol that i wrecked and sold for $500, now its got a teg front end and pullin 13.7's all motor on street tires, swapped with a stock GSR + I/H/E.
i run 14.1 w/ AC running, my 2 10's blaring mudvayne, and power steering helping me go straight on my EK hatch w/ a B swap. don't you throw your numbers around like we should be threatened.
definately good job on the turbo'ed D though, and i hope that all goes well and you can even push that d block harder and faster... i just got all emotional like a bitch about "this is for the DOHC guys"...
Old 07-15-2004, 10:15 PM
Default Re: This is for the DOHC guys. First time at the track w/the Turbo D16 sol. (citrEK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by citrEK &raquo;</TD></TR><TR><TD CLASS="quote">i don't know why you're throwing that in the face of DOHC'ers... thats not much weight to toss around. here's a link to a thread on hondavision.. its my old del Sol that i wrecked and sold for $500, now its got a teg front end and pullin 13.7's all motor on street tires, swapped with a stock GSR + I/H/E.
definately good job on the turbo'ed D though, and i hope that all goes well and you can even push that d block harder and faster... i just got all emotional like a bitch about "this is for the DOHC guys"... </TD></TR></TABLE>
lol THANKS! I saw that post on Hondavision!! That's REALLY damn fast! I thought he was on slicks though.
It says slicks in the post.
Also, I know, im sorry about that.. I was just ******* around . I always see these convos popin up and there's usually more DOHC guys than SOHC guys so i figured it's usually a little unfair. We do get ripped on all the time though so that's the main reason I posted that. You're right though it's not much weight to toss around.
BTW guys, just a FIY, my DIY kit was only $1200.
SOHC 4 life
Modified by racinskittle at 7:39 AM 7/16/2004
Old 07-15-2004, 10:55 PM
MiKeAhOwSkI's Avatar
Nice times man!
1)Turn that boost up 1.5 more psi
2)replace wal-mart tires w/ anything else.
3)fix full throttle launch settings
4) run 13's
SOHC POWER!!!
Old 07-15-2004, 10:56 PM
Milk Man's Avatar
congrats!!!
Old 07-15-2004, 11:57 PM
CivicHatchback14's Avatar
Those numbers are good for a single cam. But it's turbo. If it was a duel cam with those times(GSR or something) it would be bone stock. So it's 100% obvious that duel cams are better, and if you can't see that then...... i dunno
Old 07-16-2004, 12:02 AM
Combustion Contraption's Avatar
oh god, here we go.
Old 07-16-2004, 12:12 AM
JDMlyfestyle's Avatar
13.65@98 here with a B16 all motor. your traps seem good. but u gotta think on how the tranny is gear'd. i had a friend running 14.4 @101 with a 2.1 60'. its all about the gearing that gives u your trap speed.
Old 07-16-2004, 12:32 AM
menkio's Avatar
Default Re: (JDMlyfestyle)
wow thoose 60's are sad... you need a lot of work. Tires tires tires.. get a traction bar while your at it, and loose some more weight, You have a ok start for 12's if you can put the work in.
Old 07-16-2004, 12:58 AM
vtakk eg's Avatar
for the dohc guys???wtf.....
*my b16 laughs at your lonely cam*
Old 07-16-2004, 01:52 AM
SupraTabAx137's Avatar
Nice
Old 07-16-2004, 02:11 AM
menkio's Avatar
Default Re: This is for the DOHC guys. First time at the track w/the Turbo D16 sol. (EGmailman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGmailman &raquo;</TD></TR><TR><TD CLASS="quote">for the dohc guys???wtf.....
*my b16 laughs at your lonely cam*</TD></TR></TABLE>
https://honda-tech.com/zerothread?id=926620
da derr derr
Old 07-16-2004, 02:16 AM
JimmyAtlantis's Avatar
Default Re: This is for the DOHC guys. First time at the track w/the Turbo D16 sol. (DewMota)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DewMota &raquo;</TD></TR><TR><TD CLASS="quote">
da derr derr</TD></TR></TABLE>
LOL!!!
Pretty decent. Skittle...pretty decent. Like DewMota said, work on that 60ft.
Old 07-16-2004, 03:12 AM
Del_Slowest's Avatar
Default Re: (DewMota)
with some slicks and lowering that 60 down to 2.1 u can get a 14.0 or 13.9
Old 07-16-2004, 03:46 AM
frostcivic's Avatar
mind sharing your 1200 dollar setup?
l
Old 07-16-2004, 05:38 AM
Electrician
Deemeetree's Avatar
pwn3d
Old 07-16-2004, 05:43 AM
Former Moderator
B18C5-EH2's Avatar
Honest vehicle weight?
Old 07-16-2004, 06:12 AM
tz-devil77's Avatar
Default Re: This is for the DOHC guys. First time at the track w/the Turbo D16 sol. (B18C5-EH2)
gotta love the skittles car!
Quick Reply: This is for the DOHC guys. First time at the track w/the Turbo D16 sol.
