Does this look bad?
Does this look bad?
Just took out the spark plugs to see how they look
and it looks weird white in the inside and black around it ,
this means i am running rich?
or this is normal NGK BKR6E-11
Modified by GReddy SI at 7:05 PM 12/24/2003
Modified by GReddy SI at 7:06 PM 12/24/2003
Re: Does this look bad? (GsR HtCh)
either your running lean. either that or your cylinder walls are getting to hot which inturn can mean your running lean. what's your setup? what is the temp on those plugs 6 or 7? try running a colder spark plug
Re: Does this look bad? (allmtrwhore2)
my setup is
AEM CAI
JDM DCsports header 4-1 2.5 collector
hi flow cat 2.5 in/out
custom exhaust 2.5 staight thru
chip P28 mugen program 5400 vtec redline 8500
B16A2 us from my crashed up 2k civic si
all this and runs 14.2@95mph
AEM CAI
New User
Re: (primoEF)
White is an indication of lean as most pointed out. But the wear looks great. If you don't have a dyno, raise the fuel pressure up a few PSI. If you do have access to a dyno, I would go for some tuning!
Re: (GReddy SI)
pre ignition = pinggin.... = DONT GOOD !!!!
LOSE the mugen program !!! and you will be safe and run as fast as ever ! and not be sorry ! later !!!!
Re: (99blackcivicSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99blackcivicSi »</TD></TR><TR><TD CLASS="quote">Dude your lean and your pinging alot i would def look into a little bit of tuning to help the motor last longer</TD></TR></TABLE>
Just because he is lean does NOT mean that he is pinging. All that means is early detonation, and if he doesnt hear it than most likely, it's not happening to him. They call it pinging because that's the sound it makes. But yes, you are lean.
New User
Re: (Zeus Zore)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Zeus Zore »</TD></TR><TR><TD CLASS="quote">pre ignition = pinggin.... = DONT GOOD !!!!
LOSE the mugen program !!! and you will be safe and run as fast as ever ! and not be sorry ! later !!!!</TD></TR></TABLE>
hmmmmmm thats funny i ve been using the mugen chipped p30 in a jdm itr swap and i havent been leaning out. as for the mugen program its a more aggressive ecu wiht bettre fuel and ignition settings, you should not be leaning out using this porgram, i would try riasing your fuel pressure and what pump are u using?
heres an idea of my setup
walboro 255lph intank, with mugen program KATMAN chipped. and ive been running rich, but fine for the past year.,
Re: (Zeus Zore)
if any the only thing that the mugen ecu is advancing 2 degrees. so just up the fuel pressure up 2-5 pounds. that program is great. just get a colder plug if you want to have a sense of safety like a heat index 7 instead of 6 couldn't hurt
Re: (allmtrwhore2)
i hope thats not true, I just remembered that i adv. the timing to 18
from 16 ,
if u say the chip does it to 18 that means i am at 20
is this true?
from 16 ,
is this true?
