Does a B16 have fuel injector insulators?
Guest
Posts: n/a
My 99 Si supposed to have fuel injector insulators?
The injectors were so grimy I took em to a shop and when I got em back they didnt have injector insulators.
I never realized them BEFORE I took em to the shop because they were so dirty. But now that they are clean Im just wondering.
Thanks.
EDIT* SIDE NOTE: I'm also replacing my gaskets that go on the manifold that snug the injectors in the intake manifold; those black O rings.
(I am NOT talking about the gaskets that go on the injectors)
Am I supposed to oil them up or use gasoline before I put them on or can I put them on dry?
Thanks.
Thanks.
Thanks.
Guest
Posts: n/a
Re: Does a B16 have fuel injector insulators? (KURRRWA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KURRRWA »</TD></TR><TR><TD CLASS="quote">ya my 00 b16 had insulators but i just took them out
Explain why?
Explain why?
Guest
Posts: n/a
More horsepower ehh?
Please elaborate on that conclusion.
And the intake manifold injector O-ring gaskets, do I prep them before I put them in such as with oil or gasoline? Or can I put them in dry? THanks!
Re: Does a B16 have fuel injector insulators? (Louie_EM1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Louie_EM1 »</TD></TR><TR><TD CLASS="quote">More horsepower ehh?
Think that's the same reasoning as putting stickers on your car! Adds 5hp!
Fuel pressure keeps the fuel injectors in place anyways. I think those just help prevent dirty from getting around the o-ring seal.
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KURRRWA »</TD></TR><TR><TD CLASS="quote">much like a turbo on a D16!
adds 5hp!
yet its still slow!
Ouch
Thanks you both.
But once again; my buddie says not to prep the gaskets and to slide them in the injector than the injector into the manifold. So Im guessin I do not need to prep them?
adds 5hp!
yet its still slow!
Ouch
Thanks you both.
But once again; my buddie says not to prep the gaskets and to slide them in the injector than the injector into the manifold. So Im guessin I do not need to prep them?</TD></TR></TABLE>
Yes, put lubrication on the top o-ring of the injector before installation....unless you like a cut o-ring that will leak fuel. Its easier to install the injectors in the rail first and then install on the manifold.
Thanks.</TD></TR></TABLE>
Those donuts that go into the intake manifold, they don't need lube, just the top o-rings.
jaydmegsix
12-13-2004 12:57 AM
