Does anyone here "reuse their gaskets"?
Old 07-24-2007, 05:46 PM
egb16pg's Avatar
Default Does anyone here "reuse their gaskets"?
its not me to do it but i'd like to know if any ghetto way if they do work properly again.lol
(head,tb,intake mani,header etc.)
Old 07-24-2007, 05:48 PM
sageuvagony's Avatar
Default Re: Does anyone here "reuse their gaskets"? (egb16pg)
I've re-used the header/exhaust manifold gasket but anything else will have already been squished/ripped/shaped and won't seal the same unless replaced.
Old 07-24-2007, 06:00 PM
egb16pg's Avatar
Default Re: Does anyone here "reuse their gaskets"? (sageuvagony)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sageuvagony &raquo;</TD></TR><TR><TD CLASS="quote">I've re-used the header/exhaust manifold gasket but anything else will have already been squished/ripped/shaped and won't seal the same unless replaced.</TD></TR></TABLE>
yea i reuse that all the time. lmfaooo .
Old 07-24-2007, 06:03 PM
Mess_up's Avatar
Just depeneds on condition for me at least
Old 07-24-2007, 06:10 PM
abusedhusband's Avatar
def reuse exhaust gaskets all the time. but i once reused a headgasket and it worked.
Old 07-24-2007, 06:11 PM
samba_green_sol's Avatar
ive only reused tb. and header gaskets...id re-use and intake mani gasket if it didnt get destroyed coming off
Old 07-24-2007, 06:45 PM
egb16pg's Avatar
Default Re: (samba_green_sol)
if you look at all the service manuals, they all say replace.
Old 07-24-2007, 09:03 PM
92_VX_EG's Avatar
Default Re: (egb16pg)
That's like asking someone if they reuse condoms... I only reuse exhaust manifold gaskets and cam seals with a lot of RTV.
Old 07-24-2007, 09:07 PM
Luserkid's Avatar
Default Re: (92_VX_EG)
I reuse Exhaust, intake (hondata), TB, oil pan gasket (depends on the condition it is), and once a head gasket. Usually i try to replace all the rubber and paper type gaskets.
Old 07-24-2007, 09:43 PM
smileycvc's Avatar
Default Re: (Luserkid)
I always reuse my exhaust gasket unless it has visible flaws. I have a password IM gasket and its plastic so I reuse that. Reused a TB gasket once becuase it looked alright. I also reused a headgasket once becuase I was being cheap. This is all on my motor only. Basically if the gasket looks like you can reuse it then try it. If its torn or something then dont.
Old 07-24-2007, 10:29 PM
Maireeka's Avatar
Default Re: (smileycvc)
once, in a cheap-o-mergency, i reused a cut valve cover gasket, put it back together with rtv, sealed fine and to my knowledge it still does not leak.
Old 07-24-2007, 10:34 PM
red02s2k's Avatar
head gasket once b/c the b20 i had once only lasted three days and all the other that i thought where good
Old 07-24-2007, 10:35 PM
Default Re: (Maireeka)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Maireeka &raquo;</TD></TR><TR><TD CLASS="quote">once, in a cheap-o-mergency, i reused a cut valve cover gasket, put it back together with rtv, sealed fine and to my knowledge it still does not leak.</TD></TR></TABLE>
You'd be surprised at what people use for gaskets. I've heard it on the board here and I've heard of 2 of my friends using aluminum foil, mouse pad, old drivers license..
You can get away alot with valve cover gaskets.. Especially using RTV since it works very well.
Old 07-24-2007, 10:49 PM
* B A N N E D *
akunamatta's Avatar
well said.
Old 07-25-2007, 05:16 AM
92ehatch's Avatar
Default Re: (sageuvagony)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sageuvagony &raquo;</TD></TR><TR><TD CLASS="quote">You'd be surprised at what people use for gaskets. I've heard it on the board here and I've heard of 2 of my friends using aluminum foil, mouse pad, old drivers license..
You can get away alot with valve cover gaskets.. Especially using RTV since it works very well. </TD></TR></TABLE>
i used a piece of a cigarette pack to make a gasket for my FITV
works very well
Old 07-25-2007, 05:24 AM
speedooo's Avatar
Default Re: (92ehatch)
Ive reused intake and exhaust manifolds, exhaust gaskets, 1 tb gasket...that last 2 weeks. I just buy new to avoid problems lately
Old 07-25-2007, 07:47 AM
jus_spooln_wicha's Avatar
Default Re:
i have reused the same valve cover gasket for bout 3 years... and 2 motors.. i love that gasket bout as much as my car.. cuz its stuck with me through thick and thin, and never done me wrong! a special thanx to RTV BLACK!
Old 07-25-2007, 07:54 AM
1992Si's Avatar
I reuse the exhaust, valve cover, Hondata intake and my HDPE throttle body gasket.
Seems the only one I wouldn't reuse is a head gasket.
HDPE = High Density Polyethylene I grabbed a piece from work .020 thick when I saw what the Hondata intake gasket was.
OH_1fstgsr
08-13-2009 12:40 PM
jdmstockeg6
09-25-2007 12:21 AM
1994PreludeSi
07-11-2007 10:33 PM
Saosinx
06-27-2006 12:06 AM
black6gen
06-13-2005 01:40 PM
Quick Reply: Does anyone here "reuse their gaskets"?
